The LIFX Mini is our most compact light yet, bringing vivid color, soft whites and more control to your home via your Wi-Fi.
- Transform your space with over 16 million colors packed into a compact new light
- Light your room with the perfect white, selecting from thousands of possibilities
- Use Day & Dusk Mode to turn your lights on and off to suit your lifestyle
- Connect your LIFX Mini with leading connected home devices for further automation
Easy set up
LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. -
Built in Wi-Fi & LIFX Cloud
Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud. -
Adjustable and dimmable
Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room. -
Intuitive control
Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes. -
Bright & efficient
LIFX Mini has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
- LIFX Mini Colour - LED light bulb - E27 - 9 W - 16 million colours - 1500-9000 K - pearl white
- Light Source Type
- LED light bulb
- Pearl white
- Socket Type
- E27
- Wattage
- 9 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 1500-9000 K
- Luminous Power
- 1000 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 9 W
- E
- Energy Consumption per 1000h
- 9 kWh
- 1500-9000 K
- Colour Rendering Index
- 80
- Luminous Power
- 1000 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- 1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, voice activated, Wi-Fi controlled
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.5 Watt
- Body Colour
- Pearl white
- UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- ENERGY STAR
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 105 mm
- 144 g
- Shipping Dimensions (WxDxH) / Weight
- 63 mm x 63 mm x 125 mm / 180 g
