The LIFX Mini is our most compact light yet, bringing vivid color, soft whites and more control to your home via your Wi-Fi.
- Transform your space with over 16 million colors packed into a compact new light
 - Light your room with the perfect white, selecting from thousands of possibilities
 - Use Day & Dusk Mode to turn your lights on and off to suit your lifestyle
 - Connect your LIFX Mini with leading connected home devices for further automation
Easy set up
LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. -
Built in Wi-Fi & LIFX Cloud
Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud. -
Adjustable and dimmable
Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room. -
Intuitive control
Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes. -
Bright & efficient
LIFX Mini has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
 - LIFX Mini Colour - LED light bulb - shape: A60 - B22 - 9 W - 16 million colours - 1500-9000 K - pearl white (pack of 4)
- Light Source Type
 - LED light bulb
- Packaged Quantity
 - 4 (specifications are for single item)
 - Pearl white
- Shape
 - A60
- Socket Type
 - B22
- Wattage
 - 9 W
- Wattage Equivalent
 - 60 W
- Energy Efficiency Class
 - E
- Colour of Illumination
- Colour Temperature
 - 1500-9000 K
- Luminous Power
 - 1000 lumens
- Beam Angle
 - 250 degree(s)
- Dimmable
- Intelligent Assistant
 - Google Assistant, Alexa
- Platform
 - Apple HomeKit, Google Home
- Communications Technology
 - Wi-Fi
- Voltage Required
 - AC 100 - 240 V
- Frequency Required
 - 50/60 Hz
- Packaged Quantity
Light Source
 - LED light bulb
- Shape
 - A60
- Socket Type
 - B22
- Wattage
 - 9 W
 - 60 W
 - E
- Energy Consumption per 1000h
 - 9 kWh
 - 1500-9000 K
- Colour Rendering Index
 - 80
- Luminous Power
 - 1000 lumens
- Beam Angle
 - 250 degree(s)
- Dimmable
- Lifetime
 - 25000 hours
 - 1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, voice activated, Wi-Fi controlled
Power Requirements
- Voltage Required
 - AC 100 - 240 V
 - 50/60 Hz
- Power Consumption Stand by
 - 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
 - Wi-Fi
- Body Colour
 - Pearl white
- Package
 - Box
 - UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- ENERGY STAR
- Warranty
 - 2 years
- Diameter
 - 60 mm
- Length
 - 105 mm
 - 141 g
