Introducing the all new LIFX GU10 Downlight. Our most compact light yet, giving you vivid colours and tunable warm to cool whites everywhere in your home. This little number packs a real punch with 400 lumens from just 6 watts.
- Create on/off schedules to automate your lighting to suit your lifestyle
- Save energy with 400 lumens of light from just 6 watts
- Set the mood. Movie nights, dinner parties are better with color
- Connect your lights with your Google Home or Amazon Alexa for voice control
Versatile compatibility
Designed to seamlessly integrate into your smart home ecosystem, this light bulb is compatible with Alexa, Cortana, Google Assistant, and Siri. Whether you're using Android, iOS, or Windows devices, control your lighting with ease and convenience. -
Dynamic lighting
With a color temperature range of 2500-9000 K and the ability to display 16 million colors, this LED spot light bulb offers extensive customization. Adjust the ambiance of any room with dimmable features ranging from 1% to 100%, all controlled via Wi-Fi. -
Energy efficient
Sporting an energy efficiency class of G and a low energy consumption of 6 kWh per 1000 h, this bulb is designed to provide high-quality lighting while minimizing your energy footprint. Its standby power consumption is a mere 0.5 W, ensuring efficiency even when not in active use.
- LIFX - LED spot light bulb - GU10 - 6 W - 16 million colours - 2500-9000 K - pearl white
- Light Source Type
- Pearl white
- Socket Type
- GU10
- Wattage
- 6 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 400 lumens
- Beam Angle
- 60 degree(s)
- Dimmable
- Intelligent Assistant
- Siri, Cortana, Google Assistant, Alexa
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
Light Source
- Socket Type
- GU10
- Wattage
- 6 W
- G
- Energy Consumption per 1000h
- 6 kWh
- 2500-9000 K
- Luminous Power
- 400 lumens
- Beam Angle
- 60 degree(s)
- Dimmable
- 1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, Wi-Fi controlled
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Body Colour
- Pearl white
- MIC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- Warranty
- 2 years
- 73 mm
- Diameter
- 50 mm
- 96 g
- Shipping Dimensions (WxDxH) / Weight
- 51 mm x 51 mm x 93 mm / 126 g
