LG Electronics 84WS70MS 84" 3840x2160 DVI HDMI 4K USB LED LFD
Quicklinx: 9X89WS00 Mfr#: 84WS70MS
The sheer size of the screen, equal to four 42-inch class displays, gives you a breathtaking viewing experience. The picture is so big and immersive, it's as if you're in the scene and part of the action.
Boasting a pixel resolution 4x higher than Full HD (1080p), its detail is so vivid and crisp, even when viewed from a close distance.
  • No blackening defect
    Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas.
  • True wide viewing
    Color changes and distortion are eliminated from any viewing angle.
  • Panel stability
    Minimized image distortion when external pressure is applied.
  • 84" edge led large screen
  • Super high resolution 3,840 x 2,160 (ultra HD)
LG 84WS70MS 84" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Max Number of Screens
25
Video Interface
HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AH-IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
Remote control
Voltage
AC 120/230 V (47 - 63 Hz)
350 Watt
Power Consumption Stand by
1 Watt
192.3 cm x 10.1 cm x 110.94 cm
72.9 kg
3-year warranty
350 Watt
Diagonal Class
84"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
PC Interface
HDCP Compatible
Dimensions
Without stand
192.3 cm
10.1 cm
110.94 cm
72.9 kg
Display
LCD Display Technology
AH-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.484 x 0.484mm
Response Time
12 ms
Video Wall
25
Media Player
Supported Video Formats
DivX
Supported Audio Formats
MP3
Supported Pictures Formats
JPG
USB Port
Remote Control
Remote control
Connector Type
VGA input , Serial , HDMI input , USB , LAN , DisplayPort input , DVI-D input
VGA cable
FCC Class B certified, UL, TUV, VCCI, C-Tick, KCC
Power supply
Input Voltage
1 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years - pick-up and return
9X89 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
