LG 84WS70B are LED large screens which provides immersive wide viewing with high quality.
84" edge LED large screen
Providing immersive wide viewing with high quality. -
Hybrid type media player built-in ready
Making your signage look even slimmer and helps you maintain the system far more conveniently. -
Media player integrated solution
The solution integrated with media player foregoes the need for additional media players and allows you to cut down expenses.
- LG 84WS70B WS70 Series - 84" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 84"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 350 Watt
- Dimensions (WxDxH) - without stand
- 192.3 cm x 5.1 cm x 110.9 cm
- 72.9 kg
- Product Type
- 350 Watt
- Diagonal Class
- 84"
- Commercial Use
- Series
- WS70 Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, auto brightness sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 192.3 cm
- 5.1 cm
- 110.9 cm
- 72.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - local dimming
- Coating
- Anti-glare
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Backlight Life
- 50,000 hour(s)
- Digital signage
- Dynamic Contrast, Eye Care, Super Resolution Technology (SRT), MPEG Noise Reduction, Dynamic Color Enhancer, key lock, Dynamic Clear White, Input Labelling, compatible with SuperSign Software
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
- Connector Type
- VGA input , Serial input , 2 x HDMI input , 2 x USB , VGA output , LAN , Serial output , DVI-D input , DVI-D output , Speakers output , DisplayPort input , Composite video input , Audio output , Audio input
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Auto On/Off
- Smart energy saving
- Width (Shipping)
- 203.4 cm
- Depth (Shipping)
- 31.4 cm
- Height (Shipping)
- 121.3 cm
- Weight (Shipping)
- 87.2 kg
- 0 °C
- 40 °C
- 10 - 80%
