The Ultimate Visibility Enhancement!
Key Features:
- LED (PD Panel).
- High Brightness : 2,000nit.
- Shine-Out.
- Easy Customization (Open Frame).
- LG 47WX50MF FLATRON - 47" LCD flat panel display - Full HD - for digital signage
- Product Type
- LCD flat panel display
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Silver
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080p
- Max Number of Screens
- 225
- Video Interface
- Component, composite, HDMI
- PC Interface
- VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-IPS
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (47 - 63 Hz)
- 310 Watt
- Dimensions (WxDxH) - without stand
- 107.08 cm x 15.7 cm x 66.55 cm
- 23.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 310 Watt
- Diagonal Class
- 47"
- Commercial Use
- Series
- FLATRON
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Brightness sensor
- Video Interface
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 107.08 cm
- 15.7 cm
- 66.55 cm
- 23.9 kg
- Enclosure Colour
- Silver
Display
- LCD Display Technology
- S-IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Coating
- Hard
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1500:1
- Brightness
- 2000 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.761 x 0.761mm
- Response Time
- 9 ms
- Backlight Life
- 50,000 hour(s)
- Colour Temperature Control
- Digital daisy chain, Shine-Out
Video Wall
- 225
Video Features
- 1080p
Media Player
- USB Port
Remote Control
- Remote control
- Connector Type
- VGA input , Serial input , HDMI , Component video / composite video / VGA input , USB , Component video / composite video / VGA output , DisplayPort input , LAN , Serial output , Audio input , DVI-D output
- Cables Included
- VGA cable
- FCC Class B certified, UL, cUL, DDC-2B, CB, RoHS, KCC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.1
- Power Device
- Power supply
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
- Limited warranty - 3 years , Limited warranty - backlight - pick-up and return
- Width (Shipping)
- 118.2 cm
- Depth (Shipping)
- 26.9 cm
- Height (Shipping)
- 74.3 cm
- 0 °C
- 40 °C
- 10 - 80%
