LG Electronics 47WV50MS 47" 1920x1080 DVI HDMI LED Large Format Display
Quicklinx: 9X8HWS00 Mfr#: 47WV50MS
  • 1080p
Slimmer Bezel
4.9mm, the slimmest bezels create powerful and impactful video walls.
High Picture Quality
Clear & Vivid picture with deeper black - World Best Dynamic CR (500,000 : 1).
Auto Calibration
WV Series provide Automatic Calibration solution which enables to save time and labour on installation by adjusting the white balance on video wall easily.
Auto Higher Resolution
WV50 supports Full HD. You can enjoy super fine image from each and every displays composing videowall.
Wide Viewing Angle
Providing clear image virtually at any angle.
No Blackening Defect
No need of IR blocker or extra cooling system. Flexibly usable in various signage environment.
True Colour (IPS)
LG IPS technology provides true vivid color than conventional display.
  • Narrow bezel
    Very slim bezel - create powerful and impactful video walls.
  • High picture quality
    Clear and vivid picture with deeper black - World Best Dynamic CR.
  • Auto calibration
    WV series provide automatic calibration solution which enables to save time and labor on installation by adjusting the white balance on videowall easily.
  • Auto higher resolution
  • Wide viewing angle
  • True color (IPS)
LG 47WV50MS 47" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote control
160 Watt
Power Consumption Stand by
0.7 Watt
104.49 cm x 8.99 cm x 59 cm
18.7 kg
160 Watt
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
104.49 cm
8.99 cm
59 cm
18.7 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
800 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Certified for 24/7 Continuous Operation, compatible with SuperSign Software
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
Component video / RGB input , Composite video input , HDMI input , Serial input , USB , VGA output , LAN , Serial output , DVI-D input , DVI-D output , DisplayPort input , Audio line-in
Power supply
0.7 Watt
Smart energy saving
Width (Shipping)
118 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
77 cm
Weight (Shipping)
23.7 kg
10 - 90%
9X8H C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
