LG Electronics 43SM5C 43" 1920x1080 VGA DVI HDMI USB LED Large Format Display
Quicklinx: CXRYWS00 Mfr#: 43SM5C
  • 1080p
Quad Core SoC
The high-performance SoC can execute several tasks at the same time and provides smooth content playback.
webOS 3.0
The webOS 3.0 platform provides powerful and convenient creation tools, including app development materials.
Group Manager
Content can be created, distributed and controlled by a signage without a dedicated PC or server.
PBP (Picture-By-Picture) / PIP (Picture-In-Picture)
PBP (Picture-By-Picture) and PIP (Picture-In-Picture) features enable you to compose various layouts for several digital devices.
IP Streaming Protocol
Various types of IP video streaming protocol are supported, such as RTSP/RTP, MMS, HLS and MPEG-2 TS.
Secure Communication Protocol
By supporting HTTPS* protocol, communication between server and signage is more secure.
Proxy Server
Web access speed and security can be improved by supporting Proxy Server (A server that acts as an intermediary for requests from clients seeking resources from other servers.)
Mirroring
Content sharing is more convenient on a Wi-Fi network.
Soft AP
The SM5C with Soft AP software can operate as a wireless access point for mobile devices.
Simple Installation
Installation has been simplified by removing the external media player and Ethernet/ RS232C cables.
  • Quad-core SoC
  • webOS 3.0
  • Group manager
    Content can be created, distributed and controlled by a signagewithout a dedicated PC or server.
  • PBP (Picture-By-Picture) / PIP (Picture-In-Picture)
  • IP streaming protocol
    Various types of IP video streaming protocol are supported, such as RTSP/RTP, MMS, HLS andMPEG-2 TS.
  • Secure communication protocol
    By supporting HTTPS protocol, communication between server and signage is more secure.
  • Proxy server
    Web access speed and security can be improved by supporting proxy server.
  • Mirroring
LG 43SM5C SM5C - 43" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Platform
webOS 3.0
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Smart SoC Built-in Signage, detachable logo, SuperSign-w lite, SuperSign-c, Embedded Template, Limited Mode
Settings Cloning Capability
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote control, batteries
Voltage
75 Watt
96.96 cm x 3.86 cm x 56.39 cm
9.8 kg
Environmental Standards
ENERGY STAR Qualified
75 Watt
Diagonal Class
43"
Commercial Use
Series
SM5C
Platform
webOS 3.0
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, auto brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
96.96 cm
3.86 cm
56.39 cm
9.8 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 3H Hard
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
Commercial Features
Certified for 24/7 Continuous Operation, USB Cloning, Soft AP, Easy Brightness Control, BEACON technology, Front Polarizer, Scheduler, picture in picture (no tuner), picture by picture (no tuner)
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Configuration
8 GB
8 GB
Remote Control
Remote control
Network & Internet Multimedia
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
Connect & Share
Screen Mirroring
Connector Type
HDMI input , DisplayPort input , VGA input , DVI-D input , Serial input , LAN , USB 3.0 , Audio line-out , Serial output , DisplayPort output , Speakers output , Remote control/ambient sensor input , Audio line-in , Pixel sensor
Batteries
VGA cable
FCC Class A certified, UL, TUV, cUL, CB, EMC, KCC, KC, ERP
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 96.96 cm x 3.86 cm x 56.39 cm x 9.8 kg , Panel with stand and speakers - 96.96 cm x 19.3 cm x 62.22 cm x 12.8 kg , Panel with stand - 12.3 kg
Width (Shipping)
105.2 cm
Depth (Shipping)
12.3 cm
Height (Shipping)
65 cm
Weight (Shipping)
12.4 kg
10 - 80%
