LG Electronics 24" W2453SQ-PF 2MS VGA LCD
Quicklinx: 7CJ8WS00 Mfr#: W2453SQ-PF
The W53 SMART monitor series with cutting-edge SMART technologies that offer top picture quality while greatly reducing eyestrain during extended use.
Another of the W53 series' SMART features is cinema mode, which eliminates distractions when watching online videos. This unique setting blacks out everything except for the video clip, focusing the viewer's attention on the desired content and not on distracting ads. Continuing the working smart and reducing eyestrain theme, these monitors also include a timer that reminds users to take a break from their work at predetermined intervals. Reminders can easily be set to once per hour or at specific times through the same easy-to-use interface that controls the monitor's settings.
Helping further eliminate distractions, a proximity sensor under the W53's bezel detects when a hand approaches the screen and activates lights that make buttons easy to find when they are needed. When not in use, the lights disappear, giving the monitor a sleeker, cleaner look.
LG W2453SQ-PF - LCD monitor - Full HD (1080p) - 24"
LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
50000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Screen Coating
Anti-glare, hard coating
Voltage
Black lacquer
58.2 cm x 21.2 cm x 44.4 cm
5.3 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC/CI
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
50000:1 (dynamic)
Colour Support
Response Time
2 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
sRGB colour management, f-ENGINE technology, Digital Fine Contrast (DFC), eZ Zooming, Photo Effect
Black lacquer
5.3 kg
VGA
1 x VGA cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
42 Watt
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 3 years - on-site
