From channel selection to volume level, you can control the TV settings in public areas. Public display mode also enables you to restore default settings, as required, on the TVs. Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously. Lock mode blocks external input signals with non-compliant content. This is a useful feature for preventing misuse of TVs in various facilities or public spaces.
Public display mode
From channel selection to volume level, you can control the TV settings in public areas. Public display mode also enables you to restore default settings, as required, on the TVs. -
RS-232C control
Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously. -
Lock mode
Lock mode blocks external input signals with non-compliant content. This is a useful feature for preventing misuse of TVs in various facilities or public spaces. -
Self-diagnosis
Self-diagnosis enables engineers and IT to engineers to analyze the data and identify technical issues quickly and easily through a USB memory device. -
USB Auto Playback+
Create a media playlist of your choosing (video, music, and/or images) via USB Auto Playback+. Save it to a USB memory device, and then simply connect the USB memory device to the TV to stream your playlist sequentially. -
Welcome screen
Display a customized greeting message with your business name/logo on the TV when it is turned on. -
USB cloning
Clone your LV340C's with efficiency and ease. The USB coning feature allows you to simply copy the TV settings to all the LV340C's using a USB memory device.
- LG 49LV340C LV340C series - 49" LED-backlit LCD TV - Full HD - for digital signage / hospitality
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 49"
- Commercial Use
- Yes - digital signage / hospitality
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Commercial Features
- Screen welcome message, Lock Mode, SNMP support, Self Diagnosis, Crestron Connected Certified
- Settings Cloning Capability
- Picture Enhancements
- Triple XD Engine
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- 98.1 Watt
- Power Consumption (On mode)
- 64 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 89 kWh
- 110.7 cm x 23.5 cm x 70.1 cm
- 11.5 kg
- Product Type
- Energy Class
- Class A+
- 98.1 Watt
- 64 W
- 89 kWh
- Diagonal Class
- 49"
- Commercial Use
- Series
- LV340C series
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Modes
- Hotel mode
- Triple XD Engine
- Dimensions
- With stand
- 110.7 cm
- 23.5 cm
- 70.1 cm
- 11.5 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 24p Technology
- 24p Real Cinema
- Direct-lit LED
- Brightness
- 400 cd/m²
- Pull-Down Compensation
- 3:3
- Operation Hours / Days
- 16 / 7
- One Channel Map, security lock slot (cable lock sold separately), USB Cloning, RJP Compatible, Motion eye care, Scheduler
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Multi IR function
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Clear Voice III technology
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- HDMI input - side , USB 2.0 - side , Headphone output - side , Composite video input - rear , Component video input - rear , Audio line-in - rear , HDMI input - rear , Digital audio output (optical) - rear , VGA input - rear , Audio line-in - rear , Serial - rear , LAN , Speakers output - rear
- CB, CU
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- On/off timer, smart energy saving, WOL (Wake on LAN)
- Width (Shipping)
- 119.3 cm
- Depth (Shipping)
- 15.8 cm
- Height (Shipping)
- 77 cm
- Weight (Shipping)
- 13.5 kg
