Your window to a bright new world.
OLED that shines bright.
Heightening the vivid beauty of LG OLED self-lit pixels. Brightness Booster takes refinements by the a9 Gen 5 AI processor to the next level, delivering more luminance. Now, visuals looks bolder with superior light efficiency.
Beauty meets brains.
The brains behind the beauty. Following deep learning advancements, LG's a9 Gen 5 AI Processor enhances objects in the foreground and background to add natural depth, and makes colours spectacularly vivid yet accurate.
Dazzling darks, luminous lights.
With no backlight to dull their impact,self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss.
The details set the tone.
All-new Dynamic Tone Mapping Pro goes deeper to improve the picture. Previously, it elevated just the frames. Now, the technique hones in on 5000 blocks across the screen for more vivid HDR down to each last detail.
Sounds like you're in the scene.
The a9 Gen 5 AI Processor up-mixes 2-channel audio into virtual 7.1.2 channel sound. Feel the action and chaos around you, just like you're the main character of the movie.
Heightening the vivid beauty of LG OLED self-lit pixels. Brightness Booster takes refinements by the a9 Gen 5 AI processor to the next level, delivering more luminance. Now, visuals looks bolder with superior light efficiency. -
Beauty meets brains
The brains behind the beauty. Following deep learning advancements, LG's a9 Gen 5 AI processor enhances objects in the foreground and background to add natural depth, and makes colors spectacularly vivid yet accurate. -
With no backlight to dull their impact, self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss. -
The Dynamic Tone Mapping Pro goes deeper to improve the picture. Previously, it elevated just the frames. Now, the technique hones in on 5000 blocks across the screen for more vivid HDR down to each last detail. -
The a9 Gen 5 AI processor up-mixes 2-channel audio into virtual 7.1.2 channel sound. Feel the action and chaos around you, just like you're the main character of the movie. -
The minimalist view
With bezels this narrow, be fully immersed in the picture with nothing to distract your view. The unbelievably slim design fits seamlessly into your home with the stylish Gallery Stand and Floor Stand. -
Now, you're the main character
Dolby Vision IQ and Dolby Atmos come together for sensational immersion. Using LG's a9 Gen 5 AI processor, Dolby Vision IQ with Precision Detail adds extraordinary depth and brings out subtle textures. -
Powerful winning machine
Up your play with the first televisions in the industry to support Dolby Vision Gaming 4K for more fluid and realistic gaming. With a 0.1 ms response time, and VRR support, even ultra-fast action appears clear and smooth.
- LG OLED48C26LB C2 Series - 48" OLED TV - OLED evo - 4K
- Product Type
- OLED TV - OLED evo - Smart TV
- Diagonal Class
- 48"
- Platform
- webOS, LG ThinQ AI
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10, Dolby Vision
- HDR Technology
- Hybrid Log-Gamma (HLG), Cinema HDR, Dolby Vision IQ, HDR10 Pro
- Frame Rate & Enhancement Technology
- 120 Hz Refresh Rate, OLED Motion, Variable Refresh Rate (VRR)
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Pixel dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, YouTube, HbbTV, Catch-up TV, Now TV, RaiPlay, Apple TV, Rakuten TV, DAZN, Home Dashboard, Prime Video, Disney+, Apple TV+, LG Channels, HbbTV 2.0.1
- Picture Enhancements
- PerfectColor, Infinite Contrast, Perfect Black, Pixel Dimming, AI Brightness, Game Optimiser, Dynamic Tone Mapping Pro
- Speaker System
- 2.2 channel
- Platform
- Apple HomeKit, Google Home
- Intelligent Assistant
- Google Assistant, Alexa (not available for some languages and countries)
- USB
- 3 ports
- Included Accessories
- LG MR22GN remote control
- Voltage
- AC 100-240 V (50/60 Hz)
- Energy Class
- Class G
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 107.1 cm x 4.69 cm x 61.8 cm
- 14.9 kg
- 1-year warranty
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Power Consumption SDR (On mode)
- 66 kWh/1000h
- Power Consumption HDR (On mode)
- 120 kWh/1000h
- Diagonal Class
- 48"
- Series
- C2 Series
- Model Year
- 2022
- Platform
- Operating System
- webOS
- HDR Capable
- HDR Format
- HDR Technology
- Video Processor
- ?9 Gen 5 AI
- TV Tuner
- TV Tuner Presence
- Sensors
- Illuminance green sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Modes
- Game mode, Eco mode, Expert mode, Football Mode, Cinema mode, hotel mode, Standard mode, Gallery Mode, Vivid mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode
- Dimensions
- Without stand
- 107.1 cm
- 4.69 cm
- 61.8 cm
- 14.9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Pixel dimming
- Response Time
- 0.1 ms
- Time-shift, Cloud Gaming, 10-bit support, Virtual Reality (360 VR) function, Freesync, 4K High Frame Rate (HFR), Apple AirPlay 2 support, AI Upscaling, G-SYNC Compatible, Auto Genre Selection
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- 8-day EPG
Media Player
- Supported Video Formats
- HEVC, VP9, AV1
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2, AC4
- USB Port
- USB Ports Qty
- 3
- Configuration
- Quad-Core
Remote Control
- Remote control
- Remote Control Model
- LG MR22GN
- Voice control, NFC
Audio System
- Digital Audio Format
- Dolby Atmos
- Surround Mode
- Speaker System
- 2.2 channel
- Output Power / Total
- 40 Watt
- Bluetooth Audio Streaming, apt-X technology, Simultaneous Audio, LG Sound Sync, Intelligent Voice Recognition, Adaptive Sound Control, Enhanced Audio Return Channel (eARC), AI Acoustic Tuning, AI Sound Pro, Bluetooth Surround ready, WiSA Speaker Compatible, SoundBar Mode Control, Immersive surround sound
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Bluetooth Version
- Bluetooth 5.0
- Connect & Share
- Screen Share
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- 3 x HDMI - side , HDMI - rear , USB - side , 2 x USB - rear , 2 x audio line-out / headphones - rear , 2 x digital audio output (optical) - rear , Network - rear
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- HGiG
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Energy saving mode
- Limited warranty - 1 year
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 107.1 cm x 4.69 cm x 61.8 cm x 14.9 kg , Panel with stand - 107.1 cm x 25.1 cm x 65 cm x 18 kg
- Width (Shipping)
- 122 cm
- Depth (Shipping)
- 20.3 cm
- Height (Shipping)
- 74.5 cm
- Weight (Shipping)
- 22.4 kg
