LG 48" C2 Smart 4K Ultra HD HDR OLED TV
Quicklinx: GTWWWS00 Mfr#: OLED48C26LB.AEK
  • DVB-T
  • DVB-S
Your window to a bright new world.
OLED that shines bright.
Heightening the vivid beauty of LG OLED self-lit pixels. Brightness Booster takes refinements by the a9 Gen 5 AI processor to the next level, delivering more luminance. Now, visuals looks bolder with superior light efficiency.
Beauty meets brains.
The brains behind the beauty. Following deep learning advancements, LG's a9 Gen 5 AI Processor enhances objects in the foreground and background to add natural depth, and makes colours spectacularly vivid yet accurate.
Dazzling darks, luminous lights.
With no backlight to dull their impact,self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss.
The details set the tone.
All-new Dynamic Tone Mapping Pro goes deeper to improve the picture. Previously, it elevated just the frames. Now, the technique hones in on 5000 blocks across the screen for more vivid HDR down to each last detail.
Sounds like you're in the scene.
The a9 Gen 5 AI Processor up-mixes 2-channel audio into virtual 7.1.2 channel sound. Feel the action and chaos around you, just like you're the main character of the movie.
  • OLED that shines bright
  • Beauty meets brains
    The brains behind the beauty. Following deep learning advancements, LG's a9 Gen 5 AI processor enhances objects in the foreground and background to add natural depth, and makes colors spectacularly vivid yet accurate.
  • Dazzling darks, luminous lights
    With no backlight to dull their impact, self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss.
  • The details set the tone
    The Dynamic Tone Mapping Pro goes deeper to improve the picture. Previously, it elevated just the frames. Now, the technique hones in on 5000 blocks across the screen for more vivid HDR down to each last detail.
  • Sounds like you're in the scene
    The a9 Gen 5 AI processor up-mixes 2-channel audio into virtual 7.1.2 channel sound. Feel the action and chaos around you, just like you're the main character of the movie.
  • The minimalist view
    With bezels this narrow, be fully immersed in the picture with nothing to distract your view. The unbelievably slim design fits seamlessly into your home with the stylish Gallery Stand and Floor Stand.
  • Now, you're the main character
    Dolby Vision IQ and Dolby Atmos come together for sensational immersion. Using LG's a9 Gen 5 AI processor, Dolby Vision IQ with Precision Detail adds extraordinary depth and brings out subtle textures.
  • Powerful winning machine
    Up your play with the first televisions in the industry to support Dolby Vision Gaming 4K for more fluid and realistic gaming. With a 0.1 ms response time, and VRR support, even ultra-fast action appears clear and smooth.
LG OLED48C26LB C2 Series - 48" OLED TV - OLED evo - 4K
OLED TV - OLED evo - Smart TV
Diagonal Class
48"
Platform
webOS, LG ThinQ AI
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10, Dolby Vision
HDR Technology
Hybrid Log-Gamma (HLG), Cinema HDR, Dolby Vision IQ, HDR10 Pro
Frame Rate & Enhancement Technology
120 Hz Refresh Rate, OLED Motion, Variable Refresh Rate (VRR)
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
Pixel dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Netflix, YouTube, HbbTV, Catch-up TV, Now TV, RaiPlay, Apple TV, Rakuten TV, DAZN, Home Dashboard, Prime Video, Disney+, Apple TV+, LG Channels, HbbTV 2.0.1
Picture Enhancements
PerfectColor, Infinite Contrast, Perfect Black, Pixel Dimming, AI Brightness, Game Optimiser, Dynamic Tone Mapping Pro
Speaker System
2.2 channel
Platform
Apple HomeKit, Google Home
Intelligent Assistant
Google Assistant, Alexa (not available for some languages and countries)
USB
3 ports
LG MR22GN remote control
Voltage
AC 100-240 V (50/60 Hz)
Energy Class
Class G
Power Consumption Stand by
0.5 Watt
107.1 cm x 4.69 cm x 61.8 cm
14.9 kg
1-year warranty
Energy Class
Class G
Energy Class (HDR)
Class G
66 kWh/1000h
Power Consumption HDR (On mode)
120 kWh/1000h
Diagonal Class
48"
Series
C2 Series
Model Year
2022
Platform
webOS, LG ThinQ AI
Operating System
webOS
HDR Capable
HDR Format
HDR10, Dolby Vision
HDR Technology
Video Processor
?9 Gen 5 AI
TV Tuner
TV Tuner Presence
Sensors
Illuminance green sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
Modes
Game mode, Eco mode, Expert mode, Football Mode, Cinema mode, hotel mode, Standard mode, Gallery Mode, Vivid mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode
Dimensions
Without stand
107.1 cm
4.69 cm
61.8 cm
14.9 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Pixel dimming
Response Time
0.1 ms
Time-shift, Cloud Gaming, 10-bit support, Virtual Reality (360 VR) function, Freesync, 4K High Frame Rate (HFR), Apple AirPlay 2 support, AI Upscaling, G-SYNC Compatible, Auto Genre Selection
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 200 mm
VESA Compatibility
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
8-day EPG
Media Player
Supported Video Formats
HEVC, VP9, AV1
Supported Audio Formats
MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2, AC4
USB Port
USB Ports Qty
3
Configuration
Quad-Core
Remote Control
Remote control
Remote Control Model
LG MR22GN
Voice control, NFC
Audio System
Digital Audio Format
Dolby Atmos
Surround Mode
Speaker System
2.2 channel
Output Power / Total
40 Watt
Bluetooth Audio Streaming, apt-X technology, Simultaneous Audio, LG Sound Sync, Intelligent Voice Recognition, Adaptive Sound Control, Enhanced Audio Return Channel (eARC), AI Acoustic Tuning, AI Sound Pro, Bluetooth Surround ready, WiSA Speaker Compatible, SoundBar Mode Control, Immersive surround sound
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Bluetooth Version
Bluetooth 5.0
Connect & Share
Screen Share
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
3 x HDMI - side , HDMI - rear , USB - side , 2 x USB - rear , 2 x audio line-out / headphones - rear , 2 x digital audio output (optical) - rear , Network - rear
Internet of Things (IoT)
Platform
HGiG
Power supply
Input Voltage
0.5 Watt
Energy saving mode
Limited warranty - 1 year
Dimensions & Weight Details
Panel without stand - 107.1 cm x 4.69 cm x 61.8 cm x 14.9 kg , Panel with stand - 107.1 cm x 25.1 cm x 65 cm x 18 kg
Width (Shipping)
122 cm
Depth (Shipping)
20.3 cm
Height (Shipping)
74.5 cm
Weight (Shipping)
22.4 kg
