LG 27UK650-W 27" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: DMXWWS00 Mfr#: 27UK650-W
To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
Connect with confidence: this LG 4K monitor is compatible with the HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
  • HDR 10
  • HDR Effect
  • HDCP 2.2 compatible
  • AMD FreeSync
    With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
  • Advanced gaming features
    Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
  • On-Screen Control
    On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
  • Ergonomic stand
    The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 27UK650-W - LED monitor - 4K - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1557 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
5 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 120/230 V (50 - 60 Hz)
Silver (stand), white (back), silver (front)
61.5 cm x 20.95 cm x 45.49 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV, C-Tick, cUL, SEMKO, EN 61000-3-3, EN55024, CB, DDC/CI, RoHS, Directive 2004/108/CE, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, DisplayPort 1.2, HDCP 2.2
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1557 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SUPER + Resolution, game mode, Mega Contrast, 4-screen split, Flicker Safe, Reader Mode, Factory Calibration, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode
61.5 cm x 20.95 cm x 45.49 cm - with stand
4.9 kg
Audio
Headphone
2 x HDMI , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/+15
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), mercury free
HDMI cable , DisplayPort cable - 1.8 m
Input Voltage
30 W
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Drivers & Utilities, Dual Controller Software
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.95 cm - height: 45.49 cm - weight: 4.9 kg , Without stand - width: 61.5 cm - depth: 4.94 cm - height: 36.51 cm - weight: 4.6 kg
Shipping Width
69.4 cm
Shipping Depth
16.05 cm
Shipping Height
44 cm
Shipping Weight
6.4 kg
Sustainability Information
ENERGY STAR Certified
