LG 27MK430H 27" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: DVJJWS00 Mfr#: 27MK430H-B
IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle. With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering. Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time.
You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes. OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks. This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
  • Full HD IPS display
  • Radeon FreeSync
  • Dynamic Action Sync
  • Black stabilizer
  • OnScreen control
  • Wall mountable
LG 27MK430H-B - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/356513
Energy Class
Class F
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
62.56 cm x 20.41 cm x 46.87 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Display Type
Energy Class
Class F
37 kWh
Diagonal Size
27"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
4:3 in Wide, game mode, Mega Contrast, On-screen Digital Controls, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode, Mega DFC, 1ms Motion Blur Reduction
Matte black
62.56 cm x 20.41 cm x 46.87 cm - with stand
4.6 kg
HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
25 W
23.4 kWh/1000h
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 62.56 cm - depth: 20.41 cm - height: 46.87 cm - weight: 4.6 kg , Without stand - width: 62.56 cm - depth: 4.4 cm - height: 37.52 cm - weight: 4.2 kg
Shipping Width
70.9 cm
Shipping Depth
15.9 cm
Shipping Height
45.9 cm
Shipping Weight
6.1 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
