LG 22SM3B 22" 1920x1080 VGA HDMI USB Signage Display
Quicklinx: DLP7WS00 Mfr#: 22SM3B-B.AEK
QUAD CORE SOC
The High Performance SoC can execute several tasks at the same time and provides smooth content playback.
WEBOS 2.0
The webOS 2.0 platform provides easy and convenient tools to create content. LG’s SDK and technical support make content development and management easier.
SIMPLE INSTALLATION
Installation has been simplified by removing the external media player and Ethernet/RS232C cables.
SOFTAP
The 22SM3B with SoftAP software can operate as a wireless access point for mobile devices.
BEACON
With BEACON and Bluetooth Low Energy (BLE) supported by 22SM3B, retail stores can provide coupons and information in real-time.
  • Quad core SoC
    The high performance SoC can execute several tasks at the same time and provides smooth content playback.
  • Mirroring
    Content sharing is more convenient on a Wi-Fi network.
  • SoftAP
    SoftAP software enables a TV to operate as a wireless access point for mobile devices.
LG 22SM3B-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Input Connectors
HDMI, VGA
Built-in Ethernet
51 cm x 5.38 cm x 30.21 cm
3.6 kg
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Backlight Technology
LED backlight
51 cm x 5.38 cm x 30.21 cm - without stand
3.6 kg
HDMI (HDCP) , RGB (HD-15) , Audio line-in , RS-232C , Network (RJ-45) , USB 3.0
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x RJ-11 to RS-232 adapter
