LG  43in LED commercial TV
Quicklinx: DLT6WS00 Mfr#: 43LV340C
  • 1080p
From channel selection to volume level, you can control the TV settings in public areas. Public display mode also enables you to restore default settings, as required, on the TVs. Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously. Lock mode blocks external input signals with non-compliant content. This is a useful feature for preventing misuse of TVs in various facilities or public spaces.
  • Public display mode
  • RS-232C control
  • Lock mode
  • Self-diagnosis
    Self-diagnosis enables engineers and IT to engineers to analyze the data and identify technical issues quickly and easily through a USB memory device.
  • USB Auto Playback+
    Create a media playlist of your choosing (video, music, and/or images) via USB Auto Playback+. Save it to a USB memory device, and then simply connect the USB memory device to the TV to stream your playlist sequentially.
  • Welcome screen
    Display a customized greeting message with your business name/logo on the TV when it is turned on.
  • USB cloning
    Clone your LV340C's with efficiency and ease. The USB coning feature allows you to simply copy the TV settings to all the LV340C's using a USB memory device.
LG 43LV340C LV340C series - 43" LED-backlit LCD TV - Full HD - for digital signage / hospitality
LED-backlit LCD TV
Diagonal Class
43"
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, Lock Mode, SNMP support, SuperSign-c, Self Diagnosis, PDM (Public Display Mode), Crestron Connected Certified, USB Auto Playback+
Picture Enhancements
Triple XD Engine, Dynamic Colour Enhancer
Speaker System
2 speakers
USB
Remote control
Voltage
Energy Class
Class A+
88.7 Watt
Power Consumption (On mode)
53 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
74 kWh
97.4 cm x 22 cm x 62.5 cm
9.3 kg
LED-backlit LCD TV
Energy Class
Class A+
88.7 Watt
53 W
74 kWh
Diagonal Class
43"
Commercial Use
Series
LV340C series
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Dimensions
With stand
97.4 cm
22 cm
62.5 cm
9.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
24p Technology
24p Real Cinema
Direct-lit LED
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:3
Commercial Features
Operation Hours / Days
16 / 7
USB Cloning, RJP Compatible, Motion eye care, Certified for 16/7 Continuous Operation, Scheduler
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Media Player
Supported Video Formats
MPEG-4, DivX, WMV, ASF, AVI, MOV, M4V, MPG, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A, WMA Pro, OGG
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice technology, Optical Sound Sync
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
HDMI input - side , USB 2.0 - side , Composite video / component video input - rear , Audio line-in - rear , VGA input - rear , Audio line-in - rear , Serial - rear , Digital audio output (optical) - rear , HDMI - rear , LAN - rear , Speakers output
CB, CU-TR
Power supply
Input Voltage
0.3 Watt
Smart energy saving, WOL (Wake on LAN)
Width (Shipping)
106 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
66 cm
Weight (Shipping)
11.3 kg
