Atlona Two-Input UK Wall Plate Switcher for HDMI and VGA Inputs
Quicklinx: BTVDWS00 Mfr#: AT-HDVS-150-TX-WP-UK
The Atlona AT-HDVS-150-TX-WP features an HDMI input plus VGA input with 3.5mm audio connector and a two-gang, US two-gang wall plate. An optional face plate without buttons is also available (AT-HDVS-TX-WP-NB). Designed as a remote input device for the AT-UHD-CLSO-824 matrix switcher, the AT-HDVS-150-TX-WP combines the benefits of a switcher with built-in auto-switching and the advantages of long-distance HDBaseT signal extension over a single cable. HDMI signals up to 4K/UHD @ 60 Hz with embedded audio, VGA input signals up to 1920 x 1200 video, and control signals can be extended up to 230 feet (70 meters). The switcher enables auto display on/off, auto-switching, along with other features. The switcher receives power from the AT-UHD-CLSO-824 using Power over Ethernet. The AT-HDVS-150-TX fits inside any 40 mm deep two-gang electrical box or mud ring and is ideal for long distance transmission and display control in corporate or educational settings using analog and digital sources.
The Atlona AT-HDVS-150-TX-WP switcher expands the input capabilities of the AT-UHD-CLSO-824. Each remote switcher provides input access for up to two devices with controls for input selection and can control the power state of a display or projector when used with a third party control system. The HDVS series is designed to smooth the transition from analog to digital displays, allowing advanced HDMI display devices to be used with legacy VGA sources. The series also adds the simplicity and performance of HDBaseT technology to eliminate multiple cable runs and signal degradation that can occur with long transmission lines. Cost-effective and easy-to-terminate category cable provides additional integrator benefits.
Atlona AT-HDVS-150-TX-WP - video/audio extender - HDMI, VGA
Video/audio extender
In-wall mountable
United Kingdom
Data Transfer Rate
10.2 Gbps
HDMI, VGA
Max Transfer Distance
70 m
Power Over Ethernet (PoE)
PoE
4 cm
370 g
10 years warranty
In-wall mountable
United Kingdom
Wired
HDMI, VGA
Data Transfer Rate
10.2 Gbps
Max Resolution
4096 x 2160 @ 60 Hz
70 m
Status Indicators
Link/activity
4K resolution support, HDBaseT technology, CEC passthrough
HDCP 1.4
1 x HDMI (input) - 19 pin HDMI Type A , 1 x audio (input) - mini jack , 1 x VGA (input) - HD-15 , 1 x HDBaseT (PoE) - RJ-45
Mounting screws
Mounting Kit
Included
FCC
PoE
18.7 Watt
4 cm
370 g
Limited warranty - 10 years
50 °C
20 - 90% (non-condensing)
