The Base provides stability for your product configuration when additional input trays and output options are used.
- Lexmark printer caster base
- Product Type
- Printer caster base
- 59.4 cm x 69.3 cm x 10.7 cm
- 24.5 kg
- Designed For
- Lexmark M5155, M5163, M5170, MS710dn, MS711dn, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MS817dn, MS817n, MS818dn, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX717de, MX718de, XM5163, XM5170, XM5263, XM5270
- Product Type
- 59.4 cm - 69.3 cm - 10.7 cm
- 24.5 kg
- Designed For
