Lexmark 2100 Sheet Tray
Quicklinx: CR2HWS00 Mfr#: 40G0804
This unit supports A4, A5 (long edge first), Folio, Letter, Legal and Oficio sizes. Only Paper (16 to 36 lb, 60 to 135 gsm) may be used from this unit. Install below any other trays. Paper size, paper and tray-present and tray-low and tray-empty sensing are supported. If the product configuration contains the 2,100-Sheet Tray, the optional caster base is required.
  • Versatile media handling
    This media tray supports a wide range of media sizes including A4, A5, folio, Legal, and Oficio, making it a flexible solution for various printing needs.
  • High capacity storage
    With a total media capacity of 2100 sheets, this accessory significantly increases your printer's output without the need for frequent reloads.
Lexmark media tray - 2100 sheets
Media tray
Total Media Capacity
2100 sheets
42.2 cm x 51.1 cm x 35.1 cm
17.7 kg
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Lexmark M5155, M5163, M5170, MS710dn, MS711dn, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MS817dn, MS817n, MS818dn, MS821n, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX717de, MX718de, XM5163, XM5170, XM5263, XM5270
Media tray
2100 sheets
Media Sizes
42.2 cm - 51.1 cm - 35.1 cm
17.7 kg
