The upper bin supports up to 500 sheets of paper in A3, A4, A5, folio, executive, JIS-B4, JIS-B5, letter, legal, ledger or tabloid and statement sizes. Bin 1, the middle bin, supports up to 1500 sheets of paper in A3, A4, executive, folio, JIS-B4, JIS-B5, letter, legal and ledger or tabloid sizes. Stapling of sets of 50 sheets of paper is supported. Hole punching of paper (16 to 47 lb., 60 to 176 gsm) and offset stacking is supported. Bin 1 has an empty and a full sensor.
Bin 2, the lower bin, supports paper in A3, A4, executive, folio, JIS-B4, JIS-B5, letter, legal and ledger or tabloid sizes (16 to 24 lb., 60 to 90 gsm). The lower bin supports saddle stapling of up to 18 sets with up to 15 sheets of folded 20 lb. paper. Bin 2 has a full sensor.
- Lexmark finisher with stacker/stapler/booklet folder - 2000 sheets
- Product Type
- Finisher with stacker/stapler/booklet folder
- Punching Type
- 4-hole
- Total Media Capacity
- 2000 sheets
- Number of Media Trays
- 3
- 75 cm x 68 cm x 99.8 cm
- 43.6 kg
- Media Type
- Plain paper
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), Statement (139.7 x 215.9 mm)
- Designed For
- Lexmark C950DE, C950dte, X950DE, X950dhe, X950dhe Statoil, X950dte, X952DE, X952DTE, X954DE, X954DHE, XS950de, XS955de, XS955dhe
- Product Type
- Punching Type
- 4-hole
- 2000 sheets
- 3
- Media Type
- Plain paper
- Media Sizes
- 75 cm - 68 cm - 99.8 cm
- 43.6 kg
- Designed For
