The readers, storage drives, and hubs leverage USB 3.0 technology for high-speed performance, while the Professional Workflow HR2 hub is also designed to deliver next-generation Thunderbolt 2 speeds. Thunderbolt 2 technology gives photographers and videographers the power to quickly transfer 4K video and other large media files, at up to twice the speed of Thunderbolt and up to 4x the speed of USB 3.0 devices. The Professional Workflow HR2 hub is also backwards compatible with Thunderbolt and USB 2.0 (at slower speeds), while using the same cables and connectors.
Simply plug the readers or storage drives of choice into the hub and start transferring and archiving files. It's that easy. Also, the Professional Workflow HR2 hub provides two Thunderbolt 2 ports and one USB 3.0 port, making it easy to daisy-chain with your existing setup. Having two Thunderbolt 2 ports also allows you to place the hub anywhere in your lineup of other Thunderbolt devices to create a unique, customizable setup. The hubs help you eliminate cable clutter and take control of your workflow.
Transfer and back up images and video from multiple memory cards at once
Mix and match any of the Professional Workflow readers and storage drives with your choice of hub to create your ideal setup. Whether you choose four card readers or a combination of card readers and storage drives, the solution lets you transfer and back up your images in a single click. -
Customise your workflow with an innovative, modular design
Whether you're a pro photographer or videographer, an adventure seeker using a sports camcorder or aerial camera, or someone who needs a streamlined backup system, it's easy to create your custom workflow setup. The Professional Workflow line includes your choice of a USB 3.0 or Thunderbolt 2/USB 3.0 four-bay reader and storage drive hub, six readers, and two storage drives. Readers support SDHC/SDXC UHS-I and UHS-II, CompactFlash UDMA 7, XQD, CFast 2.0, and microSDHC/microSDXC UHS-I formats, while the storage drives are offered in 256GB and 512GB capacities. Pick and choose the right combination for your needs. And for added versatility, you can remove the readers and storage drives from the hub for individual use on the go. -
Offload your work, faster
The readers, storage drives, and hubs leverage USB 3.0 technology for high-speed performance, while the Professional Workflow HR2 hub is also designed to deliver next-generation Thunderbolt 2 speeds. Thunderbolt 2 technology gives photographers and videographers the power to quickly transfer 4K video and other large media files, at up to twice the speed of Thunderbolt and up to 4x the speed of USB 3.0 devices. The Professional Workflow HR2 hub is also backwards compatible with Thunderbolt and USB 2.0 (at slower speeds), while using the same cables and connectors. -
Quickly back up large files
Add a flash-based storage drive to a Professional Workflow hub and now you can quickly and easily store your transferred files. Leveraging USB 3.0 speeds, the drives provide read transfer speeds up to 450MB/s and write speeds up to 245MB/s. -
Simple setup and use
Simply plug the readers or storage drives of choice into the hub and start transferring and archiving files. It's that easy. Also, the Professional Workflow HR2 hub provides two Thunderbolt 2 ports and one USB 3.0 port, making it easy to daisy-chain with your existing setup. Having two Thunderbolt 2 ports also allows you to place the hub anywhere in your lineup of other Thunderbolt devices to create a unique, customizable setup. The hubs help you to eliminate cable clutter and take control of your workflow.
- Lexar Professional Workflow HR2 - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.0 , 2 x Thunderbolt 2 , 1 x USB 3.0
- Limited warranty - 2 years
