This USB Hub adds four USB-A 3.2 Gen 1 (5Gbps) ports to a USB-A enabled desktop or laptop computer. The USB Hub connects to a USB-A port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
Bus-Powered with Optional Auxiliary Power
The USB hub can operate with bus power alone, but features a Micro USB power input that can be connected to a USB power adapter (not included), providing up to 4.5W (5V/0.9A) of power in addition to the 4.5W of bus power from the USB host. This flexibility is ideal for applications where additional power may be required, such as connecting a high-powered USB device, like an external SSD, while using the other ports to connect lower powered devices. The downstream ports are each capable of providing up to 4.5W of power to the connected peripherals. For added protection to this USB hub and the connected host device, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated. -
Plug and Play
This device is OS independent, supporting all operating systems, including Windows, macOS, ChromeOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer, such as Apple MacBook, Lenovo X1 Carbon, and Dell XPS. The extra long built-in 1ft. (30 cm) USB-A host cable enables quick and convenient setup and reduces connector strain on 2-in-1 devices, such as the Surface Pro 7 and laptops on riser stands. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The applicable software for this product is the USB Event Monitoring Utility. Use this utility to track and log any connected USB devices.
- StarTech.com 4-Port USB Hub, USB 3.0 5Gbps, Bus Powered, USB-A to 4x USB-A Hub with Optional Auxiliary Power Input, Portable Desktop/Laptop USB Hub with 1ft (30cm) Attached Cable - USB Expansion Hub (5G4AB-USB-A-HUB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 3.2 Gen 1 + 1 x micro-USB
- Performance
- Data transfer rate: 5 Gbps
- USB powered, plastic housing, USB overcurrent detection and prevention
- USB 3.2 Gen 1, USB 2.0, USB 1.1
- 5.4 cm x 42 cm x 1.6 cm
- 82 g
- Space grey
- System Requirements
- Microsoft Windows, Apple MacOS, Linux, Apple iPadOS, Google Chrome OS, Android
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Performance
- Processor
- X VIA VL817
- 4 x USB 3.2 Gen 1 Type A , 1 x micro-USB input Type B
- Space grey
- Cables Included
- 1 x USB 3.2 Gen 1 cable - 30 cm
- UASP (USB Attached SCSI Protocol), RoHS, WEEE, RCM, Plug and Play
- OS Required
- 5.4 cm
- 42 cm
- 1.6 cm
- 82 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 133 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 70 °C
- 0 - 85% RH (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 80 °C
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.33 |
StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps | In Stock | £61.50 |
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans | In Stock | £150.64 |
StarTech.com Dual-Bay SATA HDD/SSD Dock | In Stock | £51.66 |
StarTech.com 3-Port USB Hub w/ GbE Adapter | In Stock | £31.24 |
StarTech.com 3-Port USB-C Hub w/ Ethernet | In Stock | £27.36 |
StarTech.com 4-Port USB-C Hub, 5Gbps | In Stock | £29.64 |
