Lexar Professional 1000x microSDHC/microSDXC UHS-II cards let you quickly capture, play back, and transfer multimedia files, including 1080p full-HD, 3D, and 4K video, with a read transfer speed up to 1000x (150MB/s).1 The cards leverage UHS-II technology (UHS Speed Class 3 (U3)) for high-speed performance, and include a microSD UHS-II USB 3.0 reader for high-speed file transfer.
High-speed performance you can trust
Whether you're a professional photographer, videographer, or a mobile device power user, these high-speed cards provide performance you can trust. They leverage UHS-II technology (UHS Speed Class 3 (U3)) and provide a read transfer speed up to 1000x (150MB/s) when used with the included SD UHS-II reader.1This gives you the speed and capacity you need to capture, transfer, and share more adventures on the go. -
Quickly transfer files with included SD UHS-II reader, dramatically accelerating workflow
Using the reader that comes with the Lexar Professional 1000x microSDHC/microSDXC UHS-II cards, you'll experience high-speed file transfer at UHS-II speeds, right out of the box. 2 This dramatically accelerates workflow from start to finish, getting you back to capturing the action faster. -
Capture adventures in HD
Calling all adventure seekers and adrenaline junkies! You can make the most of your adventures in the great outdoors by leveraging the power and performance of Lexar Professional 1000x microSDHC/microSDXC UHS-II cards. So whether you're shooting the action with your sports camcorder or an aerial camera, you can quickly capture, play back, and transfer extended lengths of the highest quality 1080p full-HD, 3D, and 4K video - making it easy to preserve more than 15 hours of your greatest moments and then relive the action.3 -
Do more with your multimedia
Also great for use with your tablet or smartphone, the cards make it easy to quickly download or save all your favorite media files, including the highest-quality movies, photos, and songs. -
Backwards compatible at the highest UHS-I speeds
For versatility, the cards are also backwards compatible with UHS-I devices, performing up to the maximum thresholds of UHS-I speed capabilities (SDR104). The cards also work with older, non-UHS-I devices, performing at Class 10 speeds. -
Recover files with Image Rescue software
Professional 1000x microSDHC/microSDXC UHS-II cards include a lifetime copy of Image Rescue software. Image Rescue recovers most photo and select video files, even if they've been erased or the card has been corrupted.4 The software is available for free download with purchase of the card. -
Outstanding compatibility
The Lexar team works with major camera manufacturers to ensure cards are compatible with their digital cameras - from the simplest to the most complex.
- Lexar Professional - flash memory card - 32 GB - microSDHC UHS-II
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-II Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- UHS Class 3 / Class10 - 1000x
- Limited lifetime warranty (Germany - 10 years)
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Rating
- 1000x
- Speed Class
- Read Rate
- Up to 150 MB/s
- Form Factor
- Included Accessories
- microSDHC card reader (USB)
- Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 1 year
- Regional Warranty Exceptions
- Germany - 10 years
