- High-speed performance—leverages UHS-II technology (U3) for a read transfer speed up to 1800x (270MB/s)
- Includes microSD™ UHS-II reader for high-speed file transfer from card to computer, dramatically accelerating workflow
- Includes an SD™ UHS-II adapter for easy transfer between devices
- Premium memory solution for sports camcorders, tablets, and smartphones
- Designed for high-speed capture of high-quality images and extended lengths of 1080p full-HD, 3D, and 4K video
- Backwards compatible with UHS-I devices, performing up to the maximum thresholds of UHS-I speed capabilities (SDR104)
- Accelerates workflow, so you can save time, beat your deadline, and gain competitive advantage
- Includes lifetime copy of downloadable Image Rescue® software Backed by expert technical support
Professional-level performance for mobile device users
UHS-II cards let you quickly capture, play back, and transfer high-definition multimedia files, including 4K video, with a read transfer speed up to 1800x (270MB/s). The cards leverage UHS-II technology for high-speed performance, and include an SD UHS-II adapter for easy transfer between devices and microSD UHS-II USB 3.0 reader for high-speed file transfer. -
High-speed performance you can trust
Whether you're a professional photographer, videographer, or a mobile device power user, Lexar Professional 1800x microSD UHS-II cards provide performance you can trust. They leverage UHS-II technology and provide a read transfer speed up to 1800x (270MB/s). This gives you the speed you need to capture, transfer, and share adventures on the go. -
Easily move and quickly transfer files
The cards come with an SD UHS-II adapter for easy transfer between devices, and a microSD UHS-II USB 3.0 reader, allowing you to experience high-speed file transfer, right out of the box. This dramatically accelerates workflow from start to finish, getting you back to capturing the action faster. -
Capture adventures in HD
Calling all adventure seekers and adrenaline junkies! Whether you're shooting the action with your sports camcorder or an aerial camera, you can quickly capture, play back, and transfer extended lengths of the highest quality 1080p full-HD, 3D, and 4K video - making it easy to preserve more than 15 hours of your greatest moments and then relive the action. -
Do more with your multimedia
Also great for use with your tablet or smartphone, the cards make it easy to quickly download or save all your favorite media files, including the highest-quality movies, photos, and songs. -
Backwards compatible at the highest UHS-I speeds
For versatility, the cards are also backwards compatible with UHS-I devices, performing up to the maximum thresholds of UHS-I speed capabilities (SDR104). The cards also work with older, non-UHS-I devices, performing at Class 10 speeds. -
Save time with dramatically accelerated workflow
The high-speed performance of Lexar Professional memory cards dramatically accelerate your workflow from start to finish, so you can save time, beat your deadline, and gain competitive advantage.
- Lexar Professional - flash memory card - 32 GB - microSDHC UHS-II
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-II Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- UHS Class 3 / Class10 - 1800x
- Included Memory Adapter
- microSDHC to SD adapter
- Software Included
- Lexar Image Rescue (free download)
- Limited lifetime warranty (Germany - 10 years)
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Rating
- 1800x
- Speed Class
- Read Rate
- Up to 270 MB/s
- Write Rate
- Up to 115 MB/s
- Form Factor
- Included Accessories
- microSDHC card reader (USB)
- Software Included
- Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 1 year
- Regional Warranty Exceptions
- Germany - 10 years
