Whether you’re a professional photographer, videographer, or adventure photography enthusiast, the Lexar® Professional 1400x XQD™ 2.0 card provides performance you can trust. This rugged, high-speed card supports both PCI Express® Gen 2 and USB 3.0 interfaces, and provides high-speed performance, durability, and reliability, with a read transfer speed up to 1400x (210MB/s).
Shoot stunning, high-quality images and 4K video. Designed to leverage the capabilities of the latest generation of high-definition camcorders and high-resolution DSLR cameras, the Lexar Professional 1400x XQD 2.0 card allows you to capture stunning, high-quality images and 4K video.
Capture adventure with ultimate durability. Whether you’re chasing sunsets or road races—or any other adventure, the Lexar Professional 1400x XQD 2.0 card delivers the rugged durability you need to get that perfect shot. It provides exceptional resilience in regards to water, temperature, shock/vibration, and more. So from the Sahara to Siberia, you have the peace of mind that you’ve got a card you can trust to capture breathtaking images.
Save time with dramatically accelerated workflow. The high-speed performance of the card allows you to quickly shoot and transfer your files. And when used with an XQD 2.0 USB 3.0 reader, such as the Lexar® Professional Workflow XR2, you’ll maximize the read transfer speed capability of the card. This dramatically accelerates your workflow from start to finish, so you can save time and get back to the business of photography.
Recover files with Image Rescue® software. The card includes version lifetime copy of Image Rescue® software. Image Rescue recovers most photo and select video files, even if they’ve been erased or the card has been corrupted. The software is available for free download with purchase of the card.
Warranty and support. All Lexar Professional line memory cards come with a limited lifetime warranty and are backed by expert technical support.
Rigorously tested. All Lexar product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 1,100 digital devices, to ensure performance, quality, compatibility, and reliability.
When memory matters, the choice is Lexar. With a long history in the industry, we know memory. We move quickly with technology to design the solutions you need, and work with device manufacturers to make sure our products are compatible. Then we stand behind them with outstanding warranties and helpful customer service. We’re dedicated to performance, reliability, and expert support, so when it comes to storing the memories that matter, trust Lexar.
For more than 15 years, Lexar has been trusted as a leading global brand of memory solutions. Our award-winning lineup includes memory cards, USB flash drives, readers, and storage drives. With so many options, it’s easy to find the right Lexar solution to fit your needs.
Designed to leverage the capabilities of the latest generation of high-definition camcorders and high-resolution DSLR cameras, the Lexar Professional 1400x XQD 2.0 card allows you to capture stunning, high-quality images and 4K video. -
Whether you're chasing sunsets or road races - or any other adventure, the Lexar Professional 1400x XQD 2.0 card delivers the rugged durability you need to get that perfect shot. It provides exceptional resilience in regards to water, temperature, shock/vibration, and more. So from the Sahara to Siberia, you have the peace of mind that you've got a card you can trust to capture breathtaking images. -
The high-speed performance of the card allows you to quickly shoot and transfer your files. And when used with an XQD 2.0 USB 3.0 reader, such as the Lexar Professional Workflow XR2, you'll maximize the read transfer speed capability of the card. This dramatically accelerates your workflow from start to finish, so you can save time and get back to the business of photography.
- Lexar Professional - flash memory card - 32 GB - XQD 2.0
- Product Type
- Flash memory card
- Form Factor
- XQD 2.0 Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- 1400x
- Software Included
- Lexar Image Rescue (free download)
- Limited lifetime warranty (Germany - 10 years)
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Rating
- 1400x
- Read Rate
- Up to 210 MB/s
- Write Rate
- Up to 80 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, temperature-proof
- Software Included
- Limited warranty - lifetime , Germany: limited warranty - 10 years
