Lexar 128GB microSDXC UHS-II 1000x with Reader (Class 10) U3
Quicklinx: BJPBWS00 Mfr#: LSDMI128CBEU1000R
Lexar Professional 1000x microSDHC/microSDXC UHS-II cards let you quickly capture, play back, and transfer multimedia files, including 1080p full-HD, 3D, and 4K video, with a read transfer speed up to 1000x (150 MB/s). The cards leverage UHS-II technology (UHS Speed Class 3 (U3)) for high-speed performance, and include a microSD UHS-II USB 3.0 reader for high-speed file transfer.
  • High-speed performance you can trust
    Whether you're a professional photographer, videographer, or a mobile device power user, these high-speed cards provide performance you can trust. They leverage UHS-II technology (UHS Speed Class 3 (U3)) and provide a read transfer speed up to 1000x (150 MB/s) when used with the included SD UHS-II reader. This gives you the speed and capacity you need to capture, transfer, and share more adventures on the go.
  • Quickly transfer files, dramatically accelerating workflow
    Using the reader that comes with the Lexar Professional 1000x microSDHC/microSDXC UHS-II cards, you'll experience high-speed file transfer at UHS-II speeds, right out of the box. Dramatically accelerates workflow from start to finish, getting you back to capturing the action faster.
  • Capture adventures in HD
    Calling all adventure seekers and adrenaline junkies! You can make the most of your adventures in the great outdoors by leveraging the power and performance of Lexar Professional 1000x microSDHC/microSDXC UHS-II cards. So whether you're shooting the action with your sports camcorder or an aerial camera, you can quickly capture, play back, and transfer extended lengths of the highest quality 1080p full-HD, 3D, and 4K video - making it easy to preserve more than 15 hours of your greatest moments and then relive the action.
  • Do more with your multimedia
    Also great for use with your tablet or smartphone, the cards make it easy to quickly download or save all your favorite media files, including the highest-quality movies, photos, and songs.
  • Backwards compatible at the highest UHS-I speeds
    For versatility, the cards are also backwards compatible with UHS-I devices, performing up to the maximum thresholds of UHS-I speed capabilities (SDR104). The cards also work with older, non-UHS-I devices, performing at Class 10 speeds.
  • Outstanding compatibility
    The Lexar team works with major camera manufacturers to ensure cards are compatible with their digital cameras - from the simplest to the most complex.
Lexar Professional - flash memory card - 128 GB - microSDXC UHS-II
Flash memory card
microSDXC UHS-II Memory Card
Storage Capacity
128 GB
Speed Rating
UHS Class 3 / Class10 - 1000x
Limited lifetime warranty (Germany - 10 years)
Flash memory card
Storage Capacity
128 GB
Speed Rating
1000x
Speed Class
Read Rate
Up to 150 MB/s
microSDXC card reader (USB)
Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 1 year
Regional Warranty Exceptions
Germany - 10 years
