Lenovo ThinkVision T24v-20 23.8" 1920x1080 4ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: G7PCWS00 Mfr#: 61FCMAT6UK
Built to empower the next-generation workforce, the ThinkVision T24v-20 redefines workplace collaboration with its smart, innovative features. This 23.8-inch monitor has an IR camera, which along with Windows Hello and enterprise-grade security, ensures instant and secure login. The camera is equipped with a physical camera shutter that works as added protection to user privacy. Dual microphones and speakers offer an enhanced VoIP meeting experience. Create a strong first impression with every presentation on its Full-HD, 3-sided NearEdgeless display that delivers brilliant clarity and outstanding visuals. Its ergonomic features offer comfort and convenience for you to work efficiently.
  • Smarter and Personalized Security
    Safety, security, and speed are the need of the hour and the IR camera, in conjunction with Windows Hello facial recognition, gives you exactly that. No need to remember passwords, or save credentials-just log in using your face. Additionally, the ThinkShutter allows you to cover your camera and the auto-alarm feature notifies you if the camera or microphone is in use, offering uncompromised privacy.
  • Effective Collaboration
    Virtual meetings will now be a breeze. The T24v's superior screen format, picture quality, and user functionality ensure that your video calls have top-notch clarity, crystal clear sound, and uninterrupted connectivity-thanks to the 2MP Full-HD camera, dual array microphones, and stereo speakers. A viewing angle of 178° makes it easy to collaborate as multiple users can view on-screen content from anywhere in the room.
  • Intuitive User Experience
    Make your meetings more comfortable and productive. An angle-adjustable camera and an ergonomic stand allow you to adjust the monitor to match your working style. Smart face-tracking technology automatically adjusts your face in the center of the screen, optimizing the display for a perfect VoIP meeting. With an ergonomic design and dedicated control keys, the T24v makes for a smart choice for any business.
Lenovo ThinkVision T24v-20 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class C
Power Consumption (On mode)
11.6 W
Microphone, microphone, USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms, 6 ms, 4 ms (extreme mode)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
53.98 cm x 20.5 cm x 43.4 cm
5.94 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
3-year warranty
Display Type
Energy Class
Class C
Diagonal Size
23.8"
Built-in Devices
Microphone, USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Eye comfort mode, 3-side NearEdgeless
Raven black
53.98 cm x 20.5 cm x 43.4 cm - with stand
5.94 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Microphone
VGA , HDMI , DisplayPort 1.2 , USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream (BC 1.2) , USB 3.2 Gen 1 upstream , Headphone/microphone combo jack
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand
1 x DisplayPort cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
11.6 W
11.6 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 53.98 cm - depth: 20.5 cm - height: 43.4 cm - weight: 5.94 kg , With stand (highest position) - width: 53.98 cm - depth: 20.5 cm - height: 58.4 cm - weight: 5.94 kg , Without stand - width: 53.98 cm - depth: 4.835 cm - height: 34.43 cm - weight: 3.48 kg
Shipping Width
64.4 cm
Shipping Depth
18.7 cm
Shipping Height
41.8 cm
Shipping Weight
7.86 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
