Lenovo ThinkVision T22i-10 21.5" 1920 x 1080 6ms HDMI LED monitor
Quicklinx: DV5GWS00 Mfr#: 61A9MAT1UK
The ThinkVision T22i-10 monitor has a concise appearance with a full-function ergonomic stand. It offers a clear display of 1920 x 1080 resolution with near edgeless IPS type screen, providing vivid images from a wide viewing angle. With built-in power and the rich connectivity of VGA, HDMI and DP, T22i-10 satisfies diverse connection demand. T22i-10 also has 4 USB 3.0 ports, including 1 with BC1.2, which offers quick charge to your USB devices. Its full-function stand supports lift, tilt, pivot CCW/CW 90-degree and swivel, which are all for your ease of use.
Lenovo ThinkVision T22i-10 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
48.97 cm x 25.19 cm x 35.76 cm
4.92 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, EAC
3-year warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72%
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP
4.92 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
16.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 10
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
