The ThinkVision T2220 21.5-inch WLED Backlit LCD Monitor meets all users' functional needs in both work and home environments. The WLED backlit panel with wide screen 1920 x 1080 resolution provides full-HD quality to customers. Its popular 16:9 aspect is increasingly becoming standard in the market. With built-in VGA + DVI interfaces and tiltable stand, it offers a comfortable usage experience. Compatible with Windows 7, Windows 8 and Windows 8.1, allowing more flexible usage. In addition, it is environmentally conscious, meeting the latest green standards including US Energy Star 6.0 Certified, TCO 6.0, China Energy Standard Tier1, EPEAT Gold Certification and VOC test.
- Lenovo ThinkVision T2220 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI, VGA
- Height, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 51.26 cm x 17.72 cm x 35.63 cm
- 6.11 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, CCC, IC, PSB, IRAM, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, MEPS, E-Standby, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, EPA 6.0, CEL Grade 1, ISC
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 307
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- Raven black
- 51.26 cm x 17.72 cm x 35.63 cm - with stand
- 6.11 kg
- DVI , VGA (DB-15)
Mechanical
- Height, tilt
- Cables Included
- 1 x VGA cable - 1.8 m
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / Windows 8, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 51.26 cm - depth: 17.72 cm - height: 35.63 cm - weight: 6.11 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
