The Lenovo ThinkVision monitor T2054p is a commercial monitor with premium product features. It contains built-in VGA + DP + HDMI interfaces and tilt stand function. It provides a wide viewing angle by IPS panel. To save space, this monitor is also designed to support ThinkCentre's Tiny PC with the Clamp Bracket. It is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TUV Green Mark, EPEAT Gold Certified, TCO Display 6.0, TCO Certified Edge 2.0, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins.
Adjustable comfort
The Lenovo ThinkVision T2054p offers comprehensive display position adjustments including height, swivel, and tilt, ensuring optimal comfort and viewing experiences for extended use. -
Vivid visuals
Featuring a 16:10 image aspect ratio, 250 cd/m2 brightness, and a 1000:1 contrast ratio, this monitor delivers crisp, bright visuals and deep blacks for a superior viewing experience. -
Efficient connectivity
With HDMI, VGA, and DisplayPort inputs, the Lenovo ThinkVision T2054p provides versatile connectivity options, making it easy to connect to various devices without the need for multiple adapters. -
Eco-friendly design
ENERGY STAR certified, the Lenovo ThinkVision T2054p is designed with energy efficiency in mind, featuring a low power consumption of just 9.6 W in on mode, making it an environmentally friendly choice for your workspace.
- Lenovo ThinkVision T2054p - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Energy Class
- Class C
- Power Consumption (On mode)
- 9.6 W
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2915 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 7 ms
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 100/240 V / DC 12 V (50/60 Hz)
- Raven black
- 45.42 cm x 24.26 cm x 34.59 cm
- 3.7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV, DDC/CI, RoHS, ISO 9241-307, WEEE, Green Mark, DDC-2B/CI, UL Environmental SPC Gold, CEL Grade 1, China RoHS, EDID compatible
- 3-year warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 19.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2915 mm
- Pixel Per Inch
- 87
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP
- Raven black
- 3.7 kg
- VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), arsenic free
- Cables Included
- 1 x VGA cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 9.6 W
- Power Consumption SDR (On mode)
- 9.6 kWh/1000h
- Power Consumption (Typical)
- 14.5 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80%
