Lenovo ThinkServer 3.5" 2TB 7.2K Enterprise SATA 6Gbps Hard Drive
Quicklinx: C47VWS00 Mfr#: 0C19503
This 7200 RPM 3.5-inch enterprise-class SATA 6 Gbps hard drive provides you with the high reliability and SATA 7200 RPM performance for your ThinkServer solution. ThinkServer 3.5 inch 7.2K RPM enterprise-class SATA drive is the perfect 3.5 inch hard drive for demanding business environments that require highly reliable and efficient high capacity storage, such as for external and internal storage, backups and archival applications. This high-capacity drive provides the ultra low cost per gigabyte to the customers.
  • Enhanced capacity
    With a generous 2 TB of storage space, this internal hard drive offers ample room for all your files, making it ideal for PC users in need of extensive storage capabilities.
  • High-speed performance
    Experience swift data transfer rates of up to 600 MBps, thanks to the Serial ATA-600 interface. This ensures quick read/write speeds, enhancing overall computer performance.
  • Reliable storage solution
    Designed for durability and dependability, this 3.5" hard drive operates at a spindle speed of 7200 rpm, providing a stable and dependable storage environment for your data.
Lenovo Enterprise Direct Connect - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
ThinkServer TD340 (3.5"); TS140 (3.5"); TS440 (3.5")
2 TB
3.5"
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Lenovo ThinkServer TD340 (3.5") , Lenovo ThinkServer TS140 (3.5") , Lenovo ThinkServer TS440 (3.5")
