Lenovo ThinkSystem 2 TB Hot Swap 3.5" SAS 12Gb
Quicklinx: FQSKWS00 Mfr#: 7XB7A00042
£277.28 ex VAT
£332.73 inc VAT
The Lenovo ThinkSystem 3.5" hard drive is a robust storage solution designed to meet the demands of modern enterprises. With a 2 TB capacity, it offers substantial space for critical data, supporting nearline storage needs with ease. The drive boasts a high data transfer rate of 1.2 GBps, enabled by the Serial Attached SCSI 3 interface, ensuring swift and efficient data handling. Its hot-swap design allows for easy maintenance and upgrades without system downtime, while the advanced format 512n and a reliable 7200 rpm spindle speed enhance its performance and durability. This hard drive is an excellent choice for businesses looking for a dependable and high-capacity storage solution.
  • Enhanced capacity
    With a generous 2 TB capacity, this Lenovo ThinkSystem hard drive offers ample space for storing large volumes of data, making it ideal for nearline storage applications where data availability and capacity are critical.
  • High-speed performance
    Experience swift data transfer rates up to 1.2 GBps, thanks to the Serial Attached SCSI 3 interface. This ensures efficient data retrieval and storage, enhancing overall system performance.
  • Reliable design
    Designed for durability and reliability, the advanced format 512n feature and a 7200 rpm spindle speed make this hard drive a solid choice for businesses seeking consistent performance and long-term reliability.
Lenovo ThinkSystem - hard drive - 2 TB - SAS 12Gb/s
Hard drive - hot-swap - nearline
2 TB
3.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
7200 rpm
Advanced format 512n
ThinkAgile MX3330-H Appliance 7D19 (3.5"); MX3331-H Certified Node 7D67 (3.5"); MX3530-H Hybrid Appliance 7D6B (3.5"); MX3531-H Hybrid Certified Node 7D66 (3.5"); ThinkAgile VX 1SE Certified Node 7Z58 (3.5"); ThinkAgile VX2330 Appliance 7Z62 (3.5"); VX3331 7Z62 (3.5"); VX5520 Appliance 7Y94 (3.5"); VX5530 Appliance 7Z63 (3.5"); VX5575 Integrated System 7D43 (3.5"); VX7531 Certified Node 7Z63 (3.5"); VX7575 Integrated System 7D43 (3.5"); VX7576 Certified Node 7D43 (3.5"); ThinkSystem SR250 (3.5"); SR530 (3.5"); SR550 (3.5"); SR570 (3.5"); SR590 (3.5"); SR630 (3.5"); SR630 V2 7Z71 (3.5"); SR645 7D2X (3.5"); SR650 (3.5"); SR650 V2 7D15 (3.5"), 7Z73 (3.5"); SR665 7D2V, 7D2W (3.5"); ST250; ST550
2 TB
3.5"
SAS 12Gb/s
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
3.5"
Lenovo ThinkAgile MX3330-H Appliance 7D19 (3.5") , Lenovo ThinkAgile MX3331-H Certified Node 7D67 (3.5") , Lenovo ThinkAgile MX3530-H Hybrid Appliance 7D6B (3.5") , Lenovo ThinkAgile MX3531-H Hybrid Certified Node 7D66 (3.5") , Lenovo ThinkAgile VX 1SE Certified Node 7Z58 (3.5") , Lenovo ThinkAgile VX2330 Appliance 7Z62 (3.5") , Lenovo ThinkAgile VX3331 7Z62 (3.5") , Lenovo ThinkAgile VX5520 Appliance 7Y94 (3.5") , Lenovo ThinkAgile VX5530 Appliance 7Z63 (3.5") , Lenovo ThinkAgile VX5575 Integrated System 7D43 (3.5") , Lenovo ThinkAgile VX7531 Certified Node 7Z63 (3.5") , Lenovo ThinkAgile VX7575 Integrated System 7D43 (3.5") , Lenovo ThinkAgile VX7576 Certified Node 7D43 (3.5") , Lenovo ThinkSystem SR250 (3.5") , Lenovo ThinkSystem SR530 (3.5") , Lenovo ThinkSystem SR550 (3.5") , Lenovo ThinkSystem SR570 (3.5") , Lenovo ThinkSystem SR590 (3.5") , Lenovo ThinkSystem SR630 (3.5") , Lenovo ThinkSystem SR630 V2 7Z71 (3.5") , Lenovo ThinkSystem SR645 7D2X (3.5") , Lenovo ThinkSystem SR650 (3.5") , Lenovo ThinkSystem SR650 V2 7D15 (3.5"), 7Z73 (3.5") , Lenovo ThinkSystem SR665 7D2V (3.5"), 7D2W (3.5") , Lenovo ThinkSystem ST250 (3.5") , Lenovo ThinkSystem ST550 (3.5")
Brand: Lenovo
