Adding more memory increases system performance. It allows you to take advantage of the ThinkStation's full potential when working with 3D imaging, digital content creation, multimedia and other memory-intensive applications.
- Lenovo - DDR3 - 4 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Dual rank, unbuffered
- Lead Plating
- Gold
- 3 years warranty
- Designed For
- ThinkStation D30 4354; E31 2552, 2553, 2555, 3688, 3690, 3691, 3695; P300 30AH, 30AK
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.2
- Speed
- ECC
- Chips Organization
- X8
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- 3 years warranty
- Designed For
- Lenovo ThinkStation D30 4354 , Lenovo ThinkStation E31 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation P300 30AH, 30AK
