Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
- Compact size
- No requirement for an ac power adapter
- Driverless operation under Microsoft Windows 7, Windows XP and Vista
- All stored data is fully encrypted using the AES 256-bit security encryption algorithm
- Real-time encryption with no read/write speed impact
- Shock-mounted 1TB 5400 rpm hard drive capacity
- Built-in USB 3.0 cable with an integral storage slot
- Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
- USB Y extension cable to ensure adequate power
- Attractive protective carrying case
- Non-skid anti-vibration pads
- High quality ThinkPad soft touch paint
- Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
- Easy and secure storage expansion
- No software installation and no power adapter required for operation
- Built-in administrative password management
- Simple file backup
- Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 5400 rpm
- Shock resistant, built-in keypad, password authentication, 256-bit AES
- Power Source
- USB bus
- 8.69 cm x 12.203 cm x 1.925 cm
- 216 g
- Pricing Type
- Customer-replaceable Unit (CRU)
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- 8.69 cm
- 12.203 cm
- 1.925 cm
- 216 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 75 MB/s
- Data Transfer Rate Details
- USB 3.0 (read): 75 MB/s , USB 3.0 (write): 55 MB/s , USB 2.0 (read): 33 MB/s , USB 2.0 (write): 25 MB/s
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable - integrated , 1 x USB extension cable - external
- UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
- Pricing Type
- Limited warranty - 3 years
- 5 °C
- 55 °C
- 5 - 95%
