LaCie eSATA Hub Thunderbolt™ Series: Give Your Storage a Thunderbolt Upgrade.*
- Connect eSATA drives to your new Mac®
- Get full speeds from eSATA drives
- Daisy chain Thunderbolt devices
- Design by Neil Poulton
Connect eSATA Drives to New Macs
Better speeds, better value. With the eSATA Hub Thunderbolt Series, now you can connect eSATA drives to your Thunderbolt-compatible Mac. Connect up to two drives to the Hub, which connects to the Thunderbolt port on your new Mac. The eSATA Hub is the perfect solution for companies that use eSATA drives, but have upgraded their Macs to versions without ExpressCard/34 slots. It also offers a great way for photographers or other creatives to boost eSATA drive performance.
Unleashing Full eSATA Speeds
The ExpressCard/34 maximum bus speed is 2.5Gb/s, which limits eSATA 3Gb/s transfer speeds. The eSATA Hub clears this bottleneck, since Thunderbolt's 10Gb/s provides more than enough speed to accommodate 3Gb/s. Achieve the full speed potential of your eSATA drives.
Bring New Value to Your Storage
You already own eSATA drives, but can't connect them to your new Mac. The eSATA Hub modernizes your drives and puts them back to work. You don't have to buy new drives and scrap the old ones. eSATA and Thunderbolt connections are even software RAID compatible. Upgrade your storage with Thunderbolt technology.
Daisy Chain for Convenience
Thunderbolt technology supports daisy chaining, so you can connect a display or other Thunderbolt device to the eSATA Hub. This means you can connect, for example, your high-end LaCie 324i display and your eSATA Hub to your Mac via a single Thunderbolt cable. Thunderbolt technology also supports two channels - one dedicated for data, and the other for video - each with 10Gb/s of bandwidth. This means you can push and pull audio/video data without reducing bandwidth. Maximum convenience, minimum desktop clutter.
Connect eSATA drives to Macs
Better speeds, better value. With the eSATA Hub Thunderbolt Series, now you can connect eSATA drives to your Thunderbolt-compatible Mac. Connect up to two drives to the Hub, which connects to the Thunderbolt port on your Mac. The eSATA Hub is the perfect solution for companies that use eSATA drives, but have upgraded their Macs to versions without ExpressCard/34 slots. It also offers a great way for photographers or other creatives to boost eSATA drive performance. -
Unleashing full eSATA speeds
The ExpressCard/34 maximum bus speed is 2.5 Gb/s, which limits eSATA 3 Gb/s transfer speeds. The eSATA Hub clears this bottleneck, since Thunderbolt's 10 Gb/s provides more than enough speed to accommodate 3 Gb/s. Achieve the full speed potential of your eSATA drives. -
Bring the value to your storage
You already own eSATA drives, but can't connect them to your Mac. The eSATA Hub modernizes your drives and puts them back to work. You don't have to buy new drives and scrap the old ones. eSATA and Thunderbolt connections are even software RAID compatible. -
Daisy chain for convenience
Thunderbolt technology supports daisy chaining, so you can connect a display or other Thunderbolt device to the eSATA hub. This means you can connect, for example, your high-end LaCie 324i display and your eSATA Hub to your Mac via a single Thunderbolt cable. Thunderbolt technology also supports two channels - one dedicated for data, and the other for video - each with 10 Gb/s of bandwidth. This means you can push and pull audio/video data without reducing bandwidth. Maximum convenience, minimum desktop clutter!
- LaCie eSATA Hub - storage controller - eSATA 3Gb/s - Thunderbolt
- Storage controller - external
- Bus Type
- Thunderbolt
- Interface
- eSATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Channel Qty
- 2
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.6 or later
- 8.5 cm x 14 cm x 4 cm
- 505 g
- 3-year warranty
- Host Bus
- Thunderbolt
Storage Controller
- Interface
- eSATA 3Gb/s
- 3 Gbit/s
- Channel Qty
- 2
- 2 x eSATA 3Gb/s
- Connections
- 2 Thunderbolt
- Included Accessories
- Stand
- Power supply
- Voltage Required
- OS Required
- Limited warranty - 3 years
- 8.5 cm
- 14 cm
- 4 cm
- 505 g
