Kyocera TK 5240Y Yellow Original Toner Cartridge
CLEARANCE!
Clearance
Price Drop
Quicklinx: CM2QWS00 Mfr#: 1T02R7ANL0
Hurry, only 1 left in stock!
£73.49 ex VAT
£88.18 inc VAT
For optimum performance we recommend genuine toner by KYOCERA Document Solutions, which is specially designed for your printer. Toner particles of the incorrect size can lead to poor print quality with streaky grey background or ghosting on the page. KYOCERA Document Solutions toner contains ceramic cleaning beads which are essential to ensure the printer drum is clean and particle free. This is particularly important as our drums are designed to last several hundred thousand copies.
A KYOCERA original toner will either have the KYOCERA Document Solutions logo moulded into the toner cassette or the toner will have a green KYOCERA Document Solutions label on it with white writing including our logo.
  • Efficient printing capacity
    Designed to support a duty cycle of up to 3,000 pages, the Kyocera TK 5240Y toner cartridge ensures consistent and reliable performance for all your printing needs. Its high yield capacity makes it an ideal choice for both home and office environments, reducing the frequency of replacements.
  • High-quality laser technology
    Utilizing advanced laser printing technology, the Kyocera TK 5240Y delivers crisp, clear, and vibrant prints. Whether you're printing documents, reports, or presentations, you can expect professional-grade results that stand out.
Kyocera TK 5240Y - yellow - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Yellow
Yield
Up to 3000 pages
Compatible with
ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Yellow
Included Qty
1-pack
Yield
Up to 3000 pages
Compatible with
Kyocera ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Brand: Kyocera
