The FS-C1020MFP color multifunction printer delivers the high performance, and vibrant color quality that image conscious businesses demand. Compact and user friendly, it provides fast and easy access to all the print, copy, scan and fax functions. With its standard duplex unit and network interface, the FS-C1020MFP is the perfect device for your office or workgroup.
Efficient connectivity
With interfaces for LAN, USB 2.0, and USB host, this device ensures seamless connection to multiple platforms, making it a versatile choice for any office environment. -
High-quality copying
Achieve crisp, clear copies quickly with a first copy out time of just 30 seconds for both black and white and color, along with a maximum copying resolution of 600 x 600 DPI. -
Robust document handling
Designed to support a wide range of media sizes and types, this device boasts a maximum media size up to Legal (216 x 356 mm), a 250-sheet input tray, and a 35-sheet Automatic Document Feeder (ADF), catering to all your document processing needs. -
Eco-friendly operation
ENERGY STAR certification ensures that this device meets strict energy efficiency guidelines, offering cost savings and a reduced environmental footprint. -
Advanced printing technology
Enjoy fast printing speeds up to 20 ppm for both black and white and color, with automatic duplexing and high resolutions up to 2400 x 600 DPI for professional-quality documents.
- Kyocera FS-C1020MFP+ - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 10000 impressions
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 140 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 90 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 751 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, Internet faxing, scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 42 cm x 49.3 cm x 47.6 cm
- 30 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty (Italy - 1 year)
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 10000 impressions
- Display
- 4 lines
- Interface
- Standard Memory
- 256 MB 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 14 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi
- Reception Memory Capacity
- Up to 100 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 20 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
Document & Media Handling
- Min Original Size
- 140 x 140 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 90 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 160 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 90 x 148 mm
- 250 sheets
- 751 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets size: 90 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , Bypass tray - 1 sheet size: 90 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , ADF - 35 sheets size: 140 x 140 mm - 216 x 356 mm weight: 52 g/m² - 105 g/m² , Output tray - 150 sheets
- Speed Details
- Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Scanning: up to 12 spm - B/W , Scanning: up to 6 spm - colour
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2.8 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2
- Voltage Required
- 382 Watt
- Power Consumption Sleep
- 10 Watt
- Warm-Up Time
- 30 sec
- First Copy Out Time B/W
- 30 sec
- First Copy Out Time Colour
- 30 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in , Italy: limited warranty - 1 year - carry-in
- 42 cm
- 49.3 cm
- 47.6 cm
- 30 kg
- Sound Emission
- 34 dBA (idle) / 58 dBA (operating)
