Kyocera ECOSYS P6230cdn Colour Laser 30ppm Printer
Quicklinx: DVBYWS00 Mfr#: 1102TV3NL1
Marketing description is not available.
  • Efficient connectivity
    With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this printer offers versatile connectivity options for any office environment.
  • High-quality printing
    Achieve professional color and B/W printing with a maximum resolution of 1200 x 1200 DPI, ensuring crisp, clear documents every time.
  • Eco-friendly design
    Certified by ENERGY STAR and compliant with ISO 14001, ISO 7779, ISO 9001, and ISO 9296 standards, this printer is designed with sustainability in mind, reducing environmental impact while maintaining efficiency.
  • Robust media handling
    Supports a wide range of media sizes from A6 to Legal and weights from 60 g/m2 to 220 g/m2, equipped with a 100-sheet multipurpose tray and a 500-sheet input tray for flexible paper handling.
  • Advanced security
    Featuring IPsec and SSL security protocols, along with SNMP 3 remote management protocol, this printer ensures secure data transmission and efficient device management.
Kyocera ECOSYS P6230cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
28.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 15 ppm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A9 1.2 GHz
RAM Installed (Max)
1 GB (1 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology
39 cm x 53.2 cm x 40.95 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Language Simulation
Colour Management Features
Mopria
Printer Features
Media Handling
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
250 sheets
Print server
Remote Management Protocol
SNMP 3
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B ¦ 2 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 3500 pages , 1 x toner cartridge (cyan) - up to 2500 pages , 1 x toner cartridge (magenta) - up to 2500 pages , 1 x toner cartridge (yellow) - up to 2500 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
466 Watt
Power Consumption Stand by
65 Watt
Power Consumption Sleep
0.6 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
49.5 dBA
39 cm
53.2 cm
40.95 cm
28.3 kg
DVBY Kyocera Black toner Cartridge for P6230CDN In Stock £89.89
