Kyocera ECOSYS MA2600cfx  Colour Laser Multifunction Printer
UP TO £125 CASHBACK OR 1 YEAR WARRANTY EXTENSION AVAILABLE!
Cashback
Quicklinx: J4K3WS00 Mfr#: 110C0F3NL0
Hurry, only 1 left in stock!
£409.71 ex VAT
£491.65 inc VAT
The Kyocera ECOSYS MA2600CFX multifunction printer offers versatile connectivity options including USB 2.0, Gigabit LAN, and mobile printing capabilities like Apple AirPrint and Microsoft Universal Print. With a maximum monthly duty cycle of 65,000 pages, this printer is designed for demanding environments. It combines printing, copying, scanning, and faxing functions, making it an ideal choice for any office setting. The user-friendly 4.3-inch touch screen display simplifies navigation and control, ensuring ease of use in any situation. Experience high-quality outputs with a maximum resolution of 1200 x 1200 DPI for both black and white and color printing. The MA2600CFX delivers speeds of up to 26 pages per minute for both printing and copying. Equipped with features like automatic duplexing and a variety of copying options including ID card copy and electronic sorting, it enhances productivity while ensuring effective document management. Security protocols such as SSL and IPsec protect sensitive information, making this printer a reliable partner for high-volume business tasks.
  • Efficient connectivity
    Supports USB 2.0, Gigabit LAN, and mobile printing options including AirPrint and Microsoft Universal Print for seamless connection and flexibility.
  • High-speed performance
    Delivers print and copy speeds of up to 26 pages per minute, meeting the demands of busy office environments.
  • Versatile copying options
    Features options such as automatic duplexing, ID card copying, and electronic sorting to enhance productivity and streamline workflows.
  • Intuitive user interface
    The 4.3-inch touch screen display simplifies navigation, allowing users to access various functions and settings with ease.
  • Robust security features
    Incorporates security protocols like SSL and IPsec, ensuring protection for sensitive documents and data while in use.
Kyocera ECOSYS MA2600CFX - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
65000 pages
Recommended Monthly Volume
900 pages
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MH, MMR, MR
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB host, USB 2.0, Gigabit LAN
AirPrint Enabled
Office Machine Features
Dual Scan Document Processor, print from USB flash drive, scan to USB host, ARM Cortex-A53 processor (1.0 GHz), scan to e-mail, scan to FTP, scan to SMB, scan to network, scan to WSD, encrypted data transfer, Job Storage, Proof and Hold, Quick Copy, Private print, EcoPrint
AC 220-240 V (50/60Hz)
41.7 cm x 42.9 cm x 49.5 cm
26 kg
1-year warranty
Printer Fonts
Outline x 93 , Windows x 8 , Bitmapped x 1 , Barcode x 46
Fax Type
Plain paper
Printing Technology
Laser - colour
65000 pages
900 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Scan-once-copy-many, electronic sorting, 2 on 1, 4 on 1, ID Card Copy, priority print, copy density control, programme mode, auto cassette change, image adjustment, reduction/zoom copy, continuous copy (1-999), Preset Reduction/Enlargement Ratios, blank page skipping
Printing
Max Printing Speed
Printer Drivers / Emulations
TIFF, PDF, JPEG, XPS, PRESCRIBE IIc, PCL 6, PCL 5c, PCL 6 (XL), KPDL3, PostScript 3, PDF 1.7, PDF 2.0
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MH, MMR, MR
Fax Resolutions
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Broadcast Transmission
Duplex Fax, Internet fax, fax polling
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Multi-purpose tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 26 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Scanning: up to 27 ipm (A4) - B/W (300 dpi) , Scanning: up to 22 ipm (A4) - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, private print
Operating System Support
MS Windows, Apple Mac OS X 10.9 or later, UNIX, Linux
375 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
29 sec
First Copy Out Time B/W
11 sec
First Copy Out Time Colour
13 sec
Consumables Included
1 x toner cartridge (black) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (cyan) - up to 1500 pages
ISO 7779, ISO 9296, GS, TUV, ISO 9001, ISO 14001, ISO 19798, UKCA, ERP, RoHS
Limited warranty - 1 year , Limited warranty - drum - 3 years or 300,000 pages , Limited warranty - developer - 3 years or 300,000 pages
41.7 cm
42.9 cm
49.5 cm
26 kg
Shipping Width
57.1 cm
Shipping Depth
59.6 cm
Shipping Height
59.9 cm
Shipping Weight
33 kg
Sound Emission
30 dBA (idle) / 48 dBA (operating)
Brand: Kyocera
