The ECOSYS M5526cdn combines the best color quality with the lowest of costs - and it will ease your workflow significantly, too. Its dual-scan document processor, the 4.3 inch touch screen for intuitive use, and program keys to simplify complex workflows improve productivity and quality this device as an absolute all-rounder. Furthermore, this device contains a long-yield toner with a capacity of up to 3,000 pages in color - offering unrivaled low costs per page. Rest assured, it is the perfect multifunctional partner for your business and will offer you a future of brilliant colors.
- Up to 26 pages per minute in A4 in colour and black and white
- 1,200 dpi printing quality
- 4,3 inch touch screen for easy operation
- Dual scan document processor
- Direct printing from and scanning to USB flash memory
- High security through SSL, IPsec and Private Print functionality
- Double-sided print, copy, scan and fax functionality as standard
- Compact design with low-noise printing
- Exceptionally low printing costs in its class
Why choose KYOCERA?
- Kyocera ECOSYS M5526cdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 26 ppm (mono) / up to 26 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
- 41.7 cm x 42.9 cm x 49.5 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Reception Memory Capacity
- Up to 256 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Remote Fax Retrieval (Polling)
- Fax polling, Duplex Fax
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - colour , Printing: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: up to 24 ipm (A4) - B/W duplex , Scanning: up to 16 ipm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- 375 Watt
- Power Consumption Standby
- 41 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 29 sec
- First Copy Out Time B/W
- 8 sec
- First Copy Out Time Colour
- 10 sec
- Consumables Included
- 1 x Cartridge (cyan) - up to 1200 pages , 1 x Cartridge (magenta) - up to 1200 pages , 1 x Cartridge (yellow) - up to 1200 pages , 1 x Cartridge (black) - up to 1200 pages
- ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 41.7 cm
- 42.9 cm
- 49.5 cm
- 26 kg
- Sound Emission
- 30 dBA (idle) / 49 dBA (operating)
