Kyocera A4 Network Document Scanner 30ppm Colour
Quicklinx: FL2HWS00 Mfr#: KVS1037XU
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The KV-S1037X network compact scanner delivers premium performance and space-saving design in abundance, offering scanning versatility that outdoes anything else in this scanning category.
  • Unmatched versatility
    The KV-S1037X scanner can scan paper and card weighing anything between 20-413gsm and offer passport scanning as standard. With unlimited long-paper capability, the scanners handle documents ranging from invoices and medical scripts to ID cards.
  • Easier operation
    The KV-S1037X scanner couldn't be easier to operate, thanks to single-touch scanning. You simply press one of the three preset buttons to scan and send the data to defined destinations.
  • Simple document management
    With Panasonic's Image Capture Plus technology, you can transfer scanned data to a PC in an image format. This means you can edit, switch or delete pages via a thumbnail interface. It also allows you to manage complicated scanned documents and file them easily.
Panasonic KV-S1037X - document scanner - desktop - Gigabit LAN, Wi-Fi, USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 mm width
Input Type
Optical Resolution
600 dpi
Interpolated Resolution
1200 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits) SP2, Microsoft Windows Server 2008 (32/64-bits) SP2, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2008 R2 SP1 (64-bits), Windows 10 (32/64 bits), Microsoft Windows Server 2003 R2 (32/64-bits) SP2, Microsoft Windows Server 2016 (64-bit)
30.3 cm x 17.7 cm x 13.7 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
216 mm width
Scanner
Input Type
Optical Resolution
600 dpi
1200 dpi
Automatic Duplexing
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - black & white - A4 / Letter - 300 dpi , 60 ipm - duplex - black & white - A4 / Letter - 300 dpi , 30 ppm - colour - A4 / Letter - 300 dpi , 60 ipm - duplex - colour - A4 / Letter - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, Long Paper Mode, Error Diffusion, Dither
Scan File Formats
JPEG
TWAIN, ISIS
Media Handling
Max Document Size
216 mm
Plain paper
Automatic
50 sheets
Interfaces Details
USB 3.1 Gen 1 , Gigabit LAN
Shading paper, control sheet, mixed batch card guide
1 x USB 3.1 cable - 1.5 m
ENERGY STAR Certified
Power Consumption Operational (Standby)
25 Watt
Power Consumption Sleep
1.6 Watt
Software Included
Drivers & Utilities, Image Capture Plus
30.3 cm
17.7 cm
13.7 cm
2.7 kg
5 °C
35 °C
20 - 80%
