Designed with the gamer and PC enthusiast in mind, its dual 60mm fans optimize airflow around the modules to help memory run at peak performance for longer periods of time. The fan is made of anodized aluminum in the same familiar blue color as the HyperX heat spreaders. When turned on, the fan blades are illuminated by eight small blue LEDs.
Efficient cooling
With an airflow of 15 cfm and a rotation speed of 3000 rpm, this memory fan unit ensures your PC components stay cool under pressure, enhancing performance and longevity. -
Sleek design
The anodized aluminum body paired with eight blue LEDs provides a sleek, modern look to your PC setup, combining functionality with style. -
Customizable control
Equipped with manual fan speed control, this unit allows for personalized cooling levels, ensuring optimal performance tailored to your needs.
- HyperX Fan - memory fan unit
- Product Type
- Memory fan unit
- Blue
- Fans Qty
- Dual
- Fan Diameter
- 60 mm
- Rotation Speed
- 3000 rpm
- Air Flow
- 15 cfm
- Power Connector
- 3-pin plug
- Blue LED x8
- Product Material
- Anodised aluminium
- 14.4 cm x 7 cm x 5.5 cm
- Manual fan speed control
- Product Type
- Memory fan unit
- Product Material
- 14.4 cm
- 7 cm
- 5.5 cm
- Blue
Heatsink & Fan
- Fans Qty
- 2
- Fan Diameter
- 60 mm
- Rotation Speed
- 3000 rpm
- Air Flow
- 15 cfm
- Power Connector
- 3-pin plug
- Blue LED x8
- Sound Emission
- 28 dBA
