Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
Apple iMac Intel Core 2 Duo 17-inch;
Apple iMac Intel Core 2 Duo 17-inch CD;
Apple iMac Intel Core 2 Duo 20-inch;
Apple iMac Intel Core 2 Duo 24-inch;
Apple iMac Intel Core Duo 17-inch;
Apple iMac Intel Core Duo 20-inch;
Apple MacBook 13-inch;
Apple MacBook Pro 15.4-inch 1.67GHz;
Apple MacBook Pro 15.4-inch 1.83GHz;
Apple MacBook Pro 15.4-inch 2.0GHz/2.16GHz;
Apple MacBook Pro 17-inch 2.16GHz.
- Kingston - DDR2 - module - 2 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- Apple MA939G/A
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 2 GB
- Upgrade Type
- System specific
- Apple MA939G/A
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
