This Kingston product has been developed using industry leading quality processes, ensuring superior quality, performance, and 100% compatibility with the device the module is designed for.
- Kingston - DDR2 - module - 2 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL6
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP KT293AA, HP 451400-001, HP 480861-001, HP GV576AA, HP KT293ET, HP 536428-001, HP 482169-003, HP 482169-002, HP 484381-001, HP 497693-001, HP 484268-002, HP 482169-004, HP 493195-001, HP 482169-001, HP 485033-004, HP KQ436-69006, HP 5189-2822, HP 598858-001, HP 506061-001, HP 506933-001
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Compaq Presario CQ20, CQ40, CQ45, CQ60; HP Business Desktop dc7800, dc7900; Pavilion s3405, s3421, s3422, s3431, s3432, s3435, s3460, s3488; Pavilion Laptop dv3, dv3600, dv3610, dv3630, dv3640, dv3650, dv3660, dv3680, dv3699, dv4, dv5, dv7, tx2513, tx2517, tx2522, tx2550, tx2627
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Latency Timings
- CL6
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
- Designed For
- HP Pavilion s3405.fr, s3421.fr, s3421.nl-m, s3421.sc, s3421.uk, s3422.af, s3422.es, s3422.it, s3422.uk, s3431.uk, s3432.nl, s3435.uk, s3460in, s3488d , HP Pavilion Laptop dv3-1075ca, dv3600ec, dv3600eg, dv3600eo, dv3610ea, dv3630eb, dv3640ew, dv3650ef, dv3650ek, dv3650el, dv3650ez, dv3660ew, dv3680es, dv3699ef, dv4-1004tu, dv4-1014nr, dv4-1035la, dv4-1041tx, dv4-1042tx, dv4-1048tx, dv4-1049tx, dv4-1090es, dv4-1125nr, dv5-1007ca, dv5-1010us, dv5-1011ea, dv5-1027eo, dv5-1070es, dv5-1089eo, dv5-1091eo, dv5-1103em, dv5-1115ec, dv5-1119em, dv5-1155ec, dv5-1192eo, dv7-1000eg, dv7-1001ef, dv7-1001tx, dv7-1003el, dv7-1003eo, dv7-1003tx, dv7-1004tx, dv7-1005eo, dv7-1006tx, dv7-1007ef, dv7-1007tx, dv7-1008ef, dv7-1008tx, dv7-1009tx, dv7-1010tx, dv7-1011tx, dv7-1012tx, dv7-1013tx, dv7-1014tx, dv7-1015el, dv7-1015tx, dv7-1016tx, dv7-1017tx, dv7-1018tx, dv7-1020ev, dv7-1020tx, dv7-1021tx, dv7-1022tx, dv7-1023em, dv7-1023tx, dv7-1024el, dv7-1024tx, dv7-1025tx, dv7-1027tx, dv7-1029tx, dv7-1030ef, dv7-1030tx, dv7-1031tx, dv7-1032tx, dv7-1033tx, dv7-1034tx, dv7-1035ef, dv7-1035em, dv7-1070ei, dv7-1090er, dv7-1100ef, dv7-1101ef, dv7-1105em, dv7-1106ef, dv7-1106eg, dv7-1107ea, dv7-1114ef, dv7-1115eg, dv7-1115ez, dv7-1116ef, dv7-1117ef, dv7-1120ef, dv7-1122eg, dv7-1123ca, dv7-1125ef, dv7-1125ez, dv7-1127cl, dv7-1127eo, dv7-1128ca, dv7-1128ez, dv7-1130eg, dv7-1130ei, dv7-1130eo, dv7-1130ew, dv7-1133cl, dv7-1134ez, dv7-1134us, dv7-1140ec, dv7-1140ek, dv7-1140es, dv7-1150ef, dv7-1150eg, dv7-1150ej, dv7-1150et, dv7-1150ew, dv7-1153ca, dv7-1157cl, dv7-1157es, dv7-1160eb, dv7-1160ek, dv7-1160eo, dv7-1160ep, dv7-1160er, dv7-1165er, dv7-1169er, dv7-1170ez, dv7-1173er, dv7-1174ca, dv7-1175eg, dv7-1175er, dv7-1179er, dv7-1180eg, dv7-1180eo, dv7-1183cl, dv7-1185eg, dv7-1190er, dv7-1190es, dv7-1195eg, dv7-1196eg, dv7-1199ec, dv7-1199es, dv7-1199ew, dv7-1199ez, tx2513cl, tx2517cl, tx2522au, tx2550ew, tx2627cl , HP Compaq Business Desktop dc7800
