Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3L - module - 16 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Quad rank, Low Voltage, registered
- Limited lifetime warranty
- Designed For
- Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M710, M710HD, M910, R410, R415, R510, R515, R610, R710, R715, R810, R815, R910, T410, T610, T710; Precision R5500, T5500, T7500
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Chips Organization
- X8
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M710, M710HD, M910, R410, R415, R510, R515, R610, R710, R715, R810, R815, R910, T410, T610, T710 , Dell Precision R5500, T5500, T7500
