Kingston 8GB Kit
Kingston 8GB Kit
Quicklinx: 6DK0WS00 Mfr#: KTL-TSD10K2/8G
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - kit - 8 GB: 2 x 4 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Fully Buffered
IBM 43R1710 (x2), IBM 43R1773 (x2)
Limited lifetime warranty (Germany, Austria and France - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
System specific
DRAM memory kit
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Fully Buffered
Compatible Slots
2 x memory - FB-DIMM 240-pin
