Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
HP Compaq ProLiant BL20p G3;
HP Compaq ProLiant DL580 G3;
HP Compaq ProLiant ML570 G3;
HP Compaq ProLiant DL360 G4p;
HP Compaq ProLiant DL380 G4;
HP Compaq ProLiant ML350 G4p.
- Kingston - DDR2 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 400 MHz / PC2-3200 - registered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 400 MHz (PC2-3200)
- Dual rank, registered
- Voltage
- 1.8 V
- OEM Manufacturer Equivalent Part Number
- HP 404122-B21
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- HPE ProLiant DL580 G3, DL580 G3 High Performance, DL580 G4, DL580 G4 High Performance, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- System specific
- HP 404122-B21
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Voltage
- 1.8 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Designed For
