Kingston 8GB CompactFlash Card
Quicklinx: 99ZVWS00 Mfr#: CF/8GB
One of the world's most popular digital mass-storage devices, CompactFlash memory cards from Kingston bridge the gap between hungry storage requirements and affordability. Users of digital cameras, PDAs and other digital devices can quickly and easily download or transfer digital files between various digital devices and the Internet, using a card that easily fits in the palm of the hand.
With the speed of a memory chip and better portability than a floppy, Kingston CompactFlash memory cards offer greater storage than many other media cards, at a fraction of the cost. They're available in a variety of capacities, so users are sure to find the right size to fit their needs. Best of all, Kingston's legendary quality and reliability are a standard feature on every card.
  • Wide temperature range
    Designed to withstand a broad range of temperatures, this Kingston CompactFlash card operates flawlessly between 0°C and 60°C, ensuring reliability and performance under various environmental conditions.
  • Versatile compatibility
    With its broad compatibility and PC support, this flash memory card seamlessly integrates with a wide array of devices, making it a suitable storage solution for diverse technological needs.
  • Optimal form factor
    The Type I CompactFlash Card form factor provides a perfect balance between size and usability, ensuring it fits perfectly in devices designed for high-quality storage solutions without compromising on portability.
Kingston - flash memory card - 8 GB - CompactFlash
Flash memory card
CompactFlash Card
Size (Type)
Type I
Storage Capacity
8 GB
Supply Voltage
3.3 / 5 V
Limited lifetime warranty (Germany, Austria and France - 10 years)
Flash memory card
Storage Capacity
8 GB
CompactFlash Card
Size (Type)
Type I
Supply Voltage
3.3 / 5 V
Regional Warranty Exceptions
36.4 mm
42.8 mm
3.3 mm
60 °C
