Easily move photos, music and data between digital devices. This all-in-one media kit gives mobile users the compatible storage they need for all SD and USB-compatible devices, including mobile phones, digital cameras, notebooks, media players and more. Store your entire mobile life - photos, songs, text messages, video clips and personal information on your card, then work with it across device platforms seamlessly with the versatile Kingston Multi-Kit/Mobility Kit at your fingertips.
Versatile compatibility
Designed to work seamlessly with both Mac and PC, this flash memory card offers a broad compatibility range, ensuring your data is accessible across different devices. -
Enhanced portability
Bundled with a USB reader and a microSDHC to SD adapter, this kit enhances the portability of your data, allowing for easy transfer and sharing across devices. -
Reliable performance
With a speed class of Class 10, this flash memory card delivers reliable and fast performance, ensuring your files are saved and accessed quickly when you need them most.
- Kingston Multi-Kit / Mobility Kit - flash memory card - 32 GB - microSDHC
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Form Factor
- microSDHC
- Storage Capacity
- 32 GB
- Speed Rating
- Class 10
- Included Memory Adapter
- microSDHC to SD adapter
- OS Required
- Microsoft Windows 7, Linux 2.6.x or later, Microsoft Windows Vista SP2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
- Limited lifetime warranty
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Storage Capacity
- 32 GB
- Speed Class
- Class 10
- Form Factor
- microSDHC
- OS Required
- Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 2 years
- 11 mm
- 15 mm
- Thickness
- 1 mm
- 0 °C
- 60 °C
