Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for Fujitsu-Siemens Lifebook N3500 Series.
- Kingston - DDR2 - module - 1 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- Fujitsu FPCEM218AP
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Fujitsu LIFEBOOK E8110, E8210, N3530, S7110 Supreme, S7110 Value
- Capacity
- 1 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
- Designed For
